VAFC vs. Hondata
Old Nov 18, 2003 | 10:05 PM
daddymaxx's Avatar
Default VAFC tuning???
With the APEXI VAFC. IS there a lot of tuning that can be done with it? Or should I just do hondata? I can probably get a VAFC pretty cheap.
Old Nov 18, 2003 | 10:08 PM
jdmspoonitr's Avatar
Default Re: VAFC tuning??? (daddymaxx)
Hondata is not much more expensive. I bought the VAFC and I wish I had a Hondata.
Old Nov 18, 2003 | 10:12 PM
daddymaxx's Avatar
well don't I have to buy a p28, and a conversion harness and then buy hondata? that soudns a lot more expensive.
Old Nov 18, 2003 | 10:45 PM
Default Re: (daddymaxx)
200 more. Not that bad. Considering all of the extra things you can do with Hondata. VAFC is very limited in what it can do.
Besides if you want to have the vafc plug and play, you have to spend 160 for the custom vafc harness.
Old Nov 18, 2003 | 11:00 PM
REFLUX's Avatar
tuning's still needed with VAFC, no?
add'l $$$$$$$
Old Nov 18, 2003 | 11:02 PM
Spartanic's Avatar
With the Hondata you'll probably have to know how to read the maps and really know how to tune the ECU to get the fullest potential out of it otherwise you can easily screw things up. But I'm pretty sure Hondata has a defualt button somwhere that'll return all fuel maps to stock.
Old Nov 18, 2003 | 11:48 PM
Bbasso's Avatar
The question is what do you have done to your caR, if its minor bolt ons then VAFC will do, But if you have more then the reg bolt ons then the Hondata would be better.
From what I understand even a completely stock R does benifit more from the Hondata then a VAFC.
First things first, what do you have done to your caR?
Old Nov 18, 2003 | 11:49 PM
daddymaxx's Avatar
ARC airbox, greddy header, mugen tiwn loop exhuast. This is in an EK.
Old Nov 18, 2003 | 11:52 PM
Bbasso's Avatar
Just curious, why did you ask this in the R forum?
anyway VAFC would be fine for now or your ek, but not really needed- but could always help.
Old Nov 18, 2003 | 11:53 PM
daddymaxx's Avatar
Asking in teh R forum because it's a JDM integra type r motor. Figured you guys would know best!
Old Nov 19, 2003 | 01:20 AM
b19coupe's Avatar
Get Hondata-then have it tuned.
Old Nov 19, 2003 | 02:44 AM
MiraiZ's Avatar
Default Re: (b19coupe)
VAFC = fuel and VTEC only
Standalone = a whole **** load of other stuff (fuel, timing, VTEC, idle speed, etc...)
in the end, if you are doing a lite tune, then VAFC may be good enough...but heavy modifications will need something more robust
Old Nov 19, 2003 | 04:27 AM
swlabhot's Avatar
with your mods the AFC should suffice but ign timing is unaddressed. Depends what u got planned for your car in the future. If big power upgrades then go Hondata. Just seems alot of $$$ to spend on standalone if u only got the current mods as you would not be making full use of its potential now
Old Nov 19, 2003 | 05:22 AM
PM-Performance's Avatar
if you have the money and need get the Hondata , the VAFC is nice , but deff has its limitiations you will find out wquick
Old Nov 19, 2003 | 07:42 AM
KRiS1's Avatar
Spend the extra loot and get the Hondata
loved his hondata
Old Nov 19, 2003 | 08:33 AM
strepto's Avatar
Default Re: VAFC tuning??? (KRiS1)
VAFC and Hondata are both great products, but they are also diffrent. I mean, VAFC is "just" a piggyback, as for Hondata, its the "whole package". I believe many choose to use them both. Hondata for basemaps, and VAFC for easy adjustment.
Old Nov 19, 2003 | 09:28 AM
daddymaxx's Avatar
so I can't do ignition timing, can't I jus tturn the distributor for that?
Old Nov 19, 2003 | 11:21 AM
b19coupe's Avatar
You can adjust the timing maps with Hondata-add a couple of degrees here, take away a couple of degrees there. You can optimize it for power.
Old Nov 19, 2003 | 12:33 PM
98cwitr's Avatar
lets add this up:
Hondata:
p28: 200
harness: 120
Hondata (s200): 295
options:
boost cap.: $200
datalogging (for the DIYers): $200
ROM editor (actual software required for the DIYers): $250
Programmer (required for the DIYers): $180
Base Total (naturally asp.): $615 + options if you wanna program it yourself or if you are running boost
ON THE OTHER HAND:
Apex-i VAFC2 - (on sale at http://www.inlinefour.com) $320 AND THATS IT
I think (go ahead and call me cheap) but the VAFC is almost half the price of hondata...not to mention saving your money up for a good 1-2 hrs on the dyno (thats a good $200 in itself).
my .02: im going with the VAFC-2, i really only just wanna lean it out, drop VTEC to 5,300 rpms, and get some gains, but thats just me.
Old Nov 19, 2003 | 12:34 PM
daddymaxx's Avatar
yea I think I just want to lean it out a bit.... I don't think I'm going to to get too much more power wiht hondata anyways.
Old Nov 19, 2003 | 12:35 PM
98cwitr's Avatar
im with the n00b...if you wanna adjust the ign timing just do it from the dist. it's just not the CoOl CoMpUtEr way to do it
daddymaxx's Avatar
so waht's the diff between VAFC and VAFC 2?
Old Nov 19, 2003 | 12:37 PM
98cwitr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daddymaxx &raquo;</TD></TR><TR><TD CLASS="quote">so waht's the diff between VAFC and VAFC 2? </TD></TR></TABLE> just that the 2 has a intergrated knock sensor and matches the interior of a ITR better
Old Nov 19, 2003 | 12:38 PM
daddymaxx's Avatar
tha'ts it? So if I can get a VAFC for sirt cheap I may as well get that one.
Old Nov 19, 2003 | 12:40 PM
daddymaxx's Avatar
ok here' sanother question.... say I go ta VAFC and did a bunch of dyno tuning on it in teh winter (which has colder air, and higher air pressure) Would I be running rich in teh summer?
