Turbo or Swap
Old Sep 12, 2001 | 12:31 PM
Spade's Avatar
Default Turbo or Swap
Should I keep my 97 ex engine and turbo it or swap it?
Good Old Daily Driver with some power
[Modified by Spade, 9:36 PM 9/12/2001]
Old Sep 12, 2001 | 12:32 PM
spyder's Avatar
New User
Default Re: Turbo or Swap (Spade)
it all depends on your long-term goals for your car... let us know what you want to do with it. drag strip monster? auto-x'er? road racer? makes a big difference.
Old Sep 12, 2001 | 12:40 PM
mschramm's Avatar
New User
another thing, how many miles on the engine, do you plan on rebuilding it before you turbo it? How fast do you really want to go? And like spyder said, what are the uses your car will see.... and do you have to worry about smog?
Old Sep 12, 2001 | 12:56 PM
Spade's Avatar
Daily driven rebuilt D16 with 20K worry about Cali Smog.
Goal is around 180+ Hp but not insane.
[Modified by Spade, 9:56 PM 9/12/2001]
Old Sep 12, 2001 | 01:04 PM
Reverend's Avatar
I think you should do a B16 because you'd get a little less hp for alot less money, then down the road, when you have more scrilla, buy the turbo for the B16 Hybrid.
[Modified by Reverend, 4:04 PM 9/12/2001]
Old Sep 12, 2001 | 01:23 PM
spyder's Avatar
New User
Default Re: Turbo or Swap (Reverend)
I concur, go with the B16. It will be fairly easy to reach your goal of 180hp without drastic measures, and you won't have to worry about being smog-legal.
Old Sep 12, 2001 | 01:25 PM
xJ.SLOTHx's Avatar
Default Re: Turbo or Swap (spyder)
yea just b16 it and then turbo it down the line....sounds good to me
Old Sep 12, 2001 | 02:14 PM
maxim's Avatar
Are you wanting a total of 180+ or do you want 180+ additional to what you have now? If the later, you will need to swap. I don't know of any turbo alone that will allow you more than 75%-85% of what you have now without internal modification. If you want a turbo to pass Smogs go for the Greddy Kit.
Old Sep 12, 2001 | 07:26 PM
b18b1slmd3dr's Avatar
New User
Swap in a B18b1and a VTEC head, turbo it and nos into the intercooler, The best of all worlds in one.
[Modified by b18b1slmd3dr, 4:29 AM 9/13/2001]
Old Sep 13, 2001 | 06:35 AM
Spade's Avatar
Default Re: Turbo or Swap (maxim_force)
I want a total of 180-220 horses.
And no I don't want an LS Vtec, that isn't worth the trouble of rebuilding the bottom end.
Old Sep 13, 2001 | 09:15 AM
maxim's Avatar
If that's the case you can get 180-220 out of a Drag or Revhard turbo no problem. That is pretty much my goal as well at the moment(around 200hp). If you decide to go with a drag kit, I would get larger injectors(310cc or 320cc??) a stage 2 clutch, Tial wg, electronic boost controller with the capability of a/r and v-tec controller(Apexi or Blitz
Old Sep 13, 2001 | 11:36 AM
GokuSSJ4's Avatar
Go with the B18c1 and then if you still want more hp then thats the perfect motor to go turbo and also you are able to put down even more hp out of the engine.Cause if you stay with your stock engine you could only do so much and with the GSR motor you could push even more (250-290hp).
Old Sep 13, 2001 | 12:11 PM
maxim's Avatar
Default Re: Turbo or Swap (Spoon1)
Maybe it's just me, but I get the idea that this guy is not interested in spending a whole lot of money. With a B18c swap you're already talking $3500+ just for the engine and all of the other conversion costs(tranny,ECU,etc...) that will go along with it, then add the $500-$1000 for installation costs, plus a turbo??? Besides, he did say he was only interested 180-220 max hp. Why spend that much more, if he's not that serious????
Old Sep 13, 2001 | 01:44 PM
Spade's Avatar
Maxim is right, I don't want to go insane and at the same time I would like to stay under 5 grand.
Old Sep 13, 2001 | 04:56 PM
memphiss13's Avatar
b20bz with a gsr trans and crower cams, valve springs and retainers, I/H/E and you're making some pretty good power. and then later on you can boost it
Old Sep 13, 2001 | 08:27 PM
Reverend's Avatar
Default Re: Turbo or Swap (rookie2nr)
Then my suggestion stands?
Old Sep 14, 2001 | 06:24 AM
Spade's Avatar
I have looked it over and finished my research, Sorry the poll didn't work. I have chosen to Turbo the D16Y8....before you jump on me let me explain, I own two civics, one is a Tuneable 97 EX and the other a pain in the rear 00 HX. I am and always will be concerned about staying California SMOG legal. There fore, I will turbo the EX with an HKS turbo since currently they are the only ones with a CARB approved turbo for the 6th Gen Civic. Then, since the EX is my wife's little toy, I will do the swap with my 00 HX....then engine, since this is way down the road and my wife has agreed that money is no object, I am doing a B18C5 changeover with a Jackson Racing supercharger. Thank you all for your suggestions but, seems that boost is the only true way to have fun.
Old Sep 14, 2001 | 07:37 AM
spyder's Avatar
New User
Sounds like a good plan to me!
Damn! Your wife RULES!
Aha! A convert! Welcome to the world of forced induction fans!
Old Sep 14, 2001 | 02:43 PM
maxim's Avatar
Have you looked into Greddy? I was under the impression that Greddy has recently designed one that will pass SMOG in CA - I could be wrong. I would check into that also if you have not already. I think you can get a Greddy kit for under $2000 w/o intercooler and $2500 w/ intercooler.
Good luck with the install.
Old Sep 14, 2001 | 06:41 PM
Spade's Avatar
according to the CARB website, the only greddy kit for civics that is approved is the 92-95 kit, putting that on a 97 will not pass smog......I don't know if I have the patience to wait for Greddy to get theres to pass but, I will drop them a line and ask.
Old Sep 15, 2001 | 09:00 AM
slowerthanu's Avatar
New User
Go simple. Swap in a B18c1 and install a Greddy Intercooled turbo kit, Get through smog and run 12's. It isnt the fastest setup, but it will be driveable in all situations and it will beat 95% of what you will come up against on the street.
Old Sep 15, 2001 | 03:21 PM
maxim's Avatar
Default Re: Turbo or Swap (slowerthanu)
what about the $$$$?
Old Sep 15, 2001 | 03:36 PM
spyder's Avatar
New User
Nevermind, question answered on F/I board.
[IGNORE]
Will the 92-95 GReddy turbo bolt right up to the '96+ or does it require modification? I don't have to worry about smog tests, so that's not an issue.
[/IGNORE]
[Modified by spyder, 7:00 PM 9/15/2001]
Old Sep 15, 2001 | 06:20 PM
DragII's Avatar
25 Year Member
Why not turbo, AND swap?
I did the turbo SOHC thing for over a year...now I'm shopping for motors
Old Sep 15, 2001 | 06:31 PM
maxim's Avatar
Default Re: Turbo or Swap (DragIIcivic)
He's looking for a quick and relatively less expensive way of getting more hp for now.
