Question on how to read the ECU part number
Old Nov 18, 2003 | 07:18 PM
Sohc Driver's Avatar
Default Question on how to read the ECU part number
Hi..i just had a simple question.....is it possible to distinguish between an obdi or obdii ecu by looking at this code:
37820-P75-A51
831-154386
Khoi
Old Nov 18, 2003 | 11:52 PM
davidjaii's Avatar
isnt p75 a 2000+ ls motor?.... im not sure but i think obd1 has 3 plugs for the ecu..
Old Nov 19, 2003 | 02:37 AM
JDM_Honda_Fiend's Avatar
Default Re: Question on how to read the ECU part number (Sohc Driver)
The P75 is from a 92-95 USDM Integra RS/LS. This ecu is an OBD1 ecu.
Old Nov 19, 2003 | 09:21 AM
96dc2's Avatar
You can go to Hondata's site next time.
ECU Part Numbers
All Honda ECUs have a part number which is located on the side of the ECU and inside the ECU on the connector. e.g. 37820-P72-A01
The part number consists of three components:
Honda's part number for ECU, which is always 37820
Three characters (which are loosely related to the model of car/engine). e.g P72
Three characters (which are the revision of the ECU) e.g. A01
The middle three characters are the most useful to identify what the ECU is. Different generation ECUs may use the same characters. e.g. a P72 OBD I ECU is different from a P72 OBD II ECU. Here is a list of common ECUs:
PG6 : 88-89 Integra (all makes)
PM5 : 88-91 Civic/CRX DX
PM6 : 88-91 Civic/CRX SOHC Si
PM7 : 89-91 DOHC ZC (JDM 'EF' ECU)
PM8 : 88-91 CRX HF
PR2 : 89-91 ZC (Euro)
PR3 : 89-91 JDM B16A EF8/9
PR3 -J00 or J51 : 92 JDM Integra B16A EF8/9
PW0 : 89-91 JDM B16A EF8/9 DA6-XSi
PR4 : 90-91 Integra LS/GS
PS9 : 88-91 4 door Civic EX Auto
P05 : 92-95 OBD-1 Civic CX
P06 : 92-95 OBD-1 Civic DX
P07 : 92-95 OBD-1 Civic VX
P08 : 92-95 OBD-1 Civic D15 JDM
P0A : 94-95 OBD-1 Accord EX
P13 : 93-95 OBD-1 Prelude Vtec
P14 : 93-95 OBD-1 Prelude Si (non Vtec)
P27 : 92-95 OBD-1 EG JDM Civic 1600 sohc
P28 : 92-95 OBD-1 Civic Si/Ex
P30 : 92-95 OBD-1 DelSol DOHC Vtec Si/EG SiR
P54-G31 : 1997 Honda Accord 1.8 LS
P61 : 92-93 OBD-1 Integra GSR
P72 : 94-95 OBD-1 Integra GSR
P72 : 96-00 OBD-2 Integra GSR
P73 : 96-00 OBD-2 Integra Type-R (JDM & USDM)
P74/75: 92-95 OBD-1 Integra LS/GS
P75 : 96-00 OBD-2 Integra LS/GS
P2N : 96+ OBD-2 Civic HX Coupe
P2P : 96+ OBD-2 Civic EX Coupe
P2E : 96+ OBD-2 Civic DX Coupe
P2M : 96+ OBD-2 NZ Civic SOHC VTEC
P2T : 99+ OBD-? Civic Si Coupe
P5P : 97-00 OBD-2 Prelude Type-S (JDM ECU)
PBA : 97+ US Acura 1.6EL
PCT : 98+ JDM ITR / CTR
PCX : 99+ OBD-? S2000
Old Nov 19, 2003 | 11:44 AM
RedTegLS's Avatar
Default Re: Question on how to read the ECU part number (96dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96dc2 &raquo;</TD></TR><TR><TD CLASS="quote">P74/75: 92-95 OBD-1 Integra LS/GS
That information is not completely accurate. I have a 95 and mine is a P75.
Berlinetta F1
Sep 1, 2007 06:06 AM
B16Jacques
Mar 14, 2005 01:34 PM
raylude
Aug 14, 2004 10:34 PM
