will a b21 90-91 si motor bolt up in a 88si with the 88 clutch and tranny?
Old Nov 18, 2003 | 03:49 PM
2156cc's Avatar
Default will a b21 90-91 si motor bolt up in a 88si with the 88 clutch and tranny?
I have a 88 si with a bad motor (rod through block) and I found a cheep b21. The b21 is out of a automatic car and I would like to use my b20 clutch and tranny. So will a b21 bolt up to a b20 tranny and drop in to a 88si? Any info will help. I tried a search and did not find anything.
Thank you, Jeremy lally
Old Nov 18, 2003 | 05:58 PM
2156cc's Avatar
Default Re: will a b21 90-91 si motor bolt up in a 88si with the 88 clutch and tranny? (2156cc)
please help!!!!!!!! bump
Old Nov 19, 2003 | 02:31 AM
JohnnyTequila's Avatar
yes, you can bolt the 88-89 tranny, to the b21.
you are going to need to use your stock clutch and flywheel, or if you are getting a new one make sure you purchase one for a 88-89 prelude.
just a heads up incase you didnt know, the B21 has oil problems and is probably why you got the motor cheap.
how cheap did you get it, because for about 600-700 you can get a JDM B20A long block which would be in better condition than the B21 and will most likely last longer. or you could get another B20A5.
Old Nov 19, 2003 | 04:53 AM
fastludeh22's Avatar
Default Re: will a b21 90-91 si motor bolt up in a 88si with the 88 clutch and tranny? (JohnnyTequila)
only prob is the b21 doesnt rev as high, so it is supposed to have a shorter geared tranny. try to find a b21 tranny to go w/it. you must match flywheel and clutch to the tranny
Old Nov 19, 2003 | 05:22 PM
2156cc's Avatar
Thanks for your help.
cheep= $75
This is just to get me back and forth to work but thanks for the heads up on the jdm stuff.
The reason I want to use the b20 tranny is because I bought it with low miles and put a act clutch in it, then the motor went south. Thanks again for your help.
bluedlude
Jun 22, 2007 12:17 PM
JLefevers
May 9, 2007 07:20 PM
lovinthecrx
May 13, 2005 08:11 PM
LoooseGSR
10
Nov 27, 2003 08:50 PM
Civic138
Aug 25, 2003 03:01 PM
