for all tha have a ls turbo, would you say a turboed ls is worth it???????????/
Old Nov 18, 2003 | 01:04 PM
blkeg's Avatar
Default for all tha have a ls turbo, would you say a turboed ls is worth it???????????/
i have a 94 civic and was about to put a gsr into but then it become around 4000 for the swap so i thought that i could get the ls swap for around 1900. does anyone hav a ls turbo. not ls/vtec just ls turbo. if so then please post your htoughts and dyno numbers or time. a friend of mine told me to buy the soch turbo kit from greddy and change the maifold. that should be good. does anyone have a ls swap for sale?
Old Nov 18, 2003 | 01:31 PM
91tegrals's Avatar
try a search a lot of people have ls t setups they usually are always happy and on a mild setup you could easilly pull 210-220 and the turn up the boost at the track and get up to 250 on a stock block...
Old Nov 18, 2003 | 01:43 PM
quikB18B's Avatar
Default Re: (91tegrals)
I woudl take a gsr turbo setup over an ls any day, but you cant beat the price(bang for the buck) of the turbo ls setup
First off let me say $1900 is way overpriced for an ls swap, a complete one with low miles shoudl run you about $1,500 tops.
For 4k you coudl make between 260-290 whp safely! On a basic ls turbo setup most make around 200-230 on 7-9 psi.
Hondata has done wonders with stock hoinda motors these days. SOme of my friends setups
*Direp972 230/200 on revhard kit 8 psi
Direp972 274/24x on 12 psi hondata/stock mtr/550cc
4u2nv 280/242 10.5 psi hondata/550 setup is now in redlinegsr's car
Hybridcivicls-T 265/23x 10 psi hondata 550cc
So far i ahve spent a total of $3,200 for my complete custom turbo setup, this inclused everything turbo kit, gauges, exhuast, down to all the bolts,studs, ect...
Im jaunaury im upgrading to hondata/550cc/tuning
This will run me another 1000
so for about 4k im going to be making close to 300 if not 300 with 4k in my lil ole ls motor, not bad if you ask me
If your looking for the most power out of your 4k then turbo ls is the way to go.
Old Nov 18, 2003 | 03:13 PM
Hites
Guest
Posts: n/a
Default Re: for all tha have a ls turbo, would you say a turboed ls is worth it???????????/ (blkeg)
$1900 for an ls swap!? i paid $450 for my ls long block!
Old Nov 18, 2003 | 05:29 PM
shawn_crx's Avatar
Default Re: for all tha have a ls turbo, would you say a turboed ls is worth it???????????/ (Hites)
i guess it depend what state you are in.
There this shop going to charge me 3000 for an completed ls swap.
Included labor too.
Old Nov 18, 2003 | 05:35 PM
integranator's Avatar
Default Re: for all tha have a ls turbo, would you say a turboed ls is worth it???????????/ (shawn_crx)
I ran a 13.70 @105 on **** *** kumhoes @6psi. untuned
t3/04e 57trim
maxrev manifold
pwr i.c.
2.5" dp
450CC for afc hack
Old Nov 18, 2003 | 05:47 PM
billybong91DA's Avatar
my buddy has an ls turbo in a 91 civic hatch, with full interior
57 trim turbonetics t3/t4
custom manifold
custom piping
tial bov
tial wastegate
spearco front mount
turbo xs manual boost controller
cometich head gasket
block guard
60 mm bbk throttle body
msd ignition
skunk 2 intake manifold
b&m fuel pressure regulator
b&M fuel pump
ran 11.37 spinning BFG Comp T/A radials through fourth gear
Old Nov 18, 2003 | 06:04 PM
NuclearB18B's Avatar
Default Re: (quikB18B)
i my turbo ls.
Old Nov 18, 2003 | 07:30 PM
90tegTN's Avatar
Default Re: (ha illuminato un)
3000??????? ok, just so u know for a ls swap, you could ship your car to Tennessee, let me give u a rebuilt ls complete swap, send it back and still save tons and thats talkin, new apr rod bolts (give out easily) lower compression pistons) , apr head bolts, etc.. etc.... and I gaurantee that your shop is not going to do what is right if they are that insane...... 3000 would almost get you a b18c1.... thats more realistic... or maybe a b16a2... complete swap, but that too, is realitively cheaper than the price u gave
Old Nov 19, 2003 | 05:01 AM
quikB18B's Avatar
Default Re: (90tegTN)
For 3k you could buy a gsr swap and do it yourself
I wouldnt be able to sleep at night If I knew a honda-tech member paid 3k for an Ls swap .
Old Nov 19, 2003 | 06:57 AM
espanol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">For 3k you could buy a gsr swap and do it yourself
I wouldnt be able to sleep at night If I knew a honda-tech member paid 3k for an Ls swap . </TD></TR></TABLE>
i guess it depends on the swap. people have brought in these magical $1500 complete swaps and their garbage.most of the time every oil seal is leaking, sensors are trashed, axles are broken,there's high mileage on the motoe and the water pump and oil pump are garbage.you can end up spending more than 3 grand right away.
Old Nov 19, 2003 | 07:28 AM
Loccster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn_crx &raquo;</TD></TR><TR><TD CLASS="quote">i guess it depend what state you are in.
Included labor too. </TD></TR></TABLE>
$3k for a ls swap in TEXAS??? I'd rather spend that $3k for a real "horse" and some cowboy boots
Old Nov 19, 2003 | 07:33 AM
RedTegLS's Avatar
$3000 for an LS swap? Holy crap! I will sell you my complete LS motor for $600 and you can do what you want from there. Just to put the installation into perspective, my friend who is not a certified mechanic, swapped a complete GSR motor into a civic hatch BY HIMSELF in one night with simple tools and an engine hoist!
Old Nov 19, 2003 | 07:42 AM
rusteds2k's Avatar
What shop is this? My friends can do the swap for less than 2k. We're around dallas.
As for Ls turbo, talk to HybridcivicLS-T. He running 11psi on his Stock motor. (cool guy)
Old Nov 19, 2003 | 08:00 AM
B18bEK's Avatar
i think LS turbo is fun
JLopezDC2
Jul 31, 2012 10:06 PM
JENNY_EG6
Jul 10, 2009 10:51 AM
killablaze
Oct 7, 2005 04:06 PM
sdpuck
Oct 26, 2004 07:11 AM
