Need help resetting ECU of TPS sensor
Guest
Posts: n/a
I just swapped in a h22a w/LSD in my 6th gen accord. it gave me two codes: the knock sensor and the TPS. I wired up the knock sensor correctly and it fixed that problem but it left the TPS sensor. I looked and checked everything and it was connected fine. Still same code. I swapped out the TPS sensor from my original f23 and disconnected the battery. And it still pull the CEL for my TPS and i know my original TPS sensor worked fine, is there any other place i can reset the ecu to get rid of it??
should be inside the car. On my 99 Odyssey there's a fuse box in the pass. kick panel. Yours is probably under the dash. And also, it's the "clock backup" fuse if you're going by name alone. (7.5AMPS)
Modified by nuc79 at 2:07 AM 11/19/2003
