axles on 2gen and 3gen tegs?
Old Nov 18, 2003 | 10:27 AM
90teg's Avatar
Default axles and injectors on 2gen and 3gen tegs?
does axles from a 90-93 teg fit the 3gen tegs? also does anyone know what kind of injectors(94-95 LS tegs) have, peak hold or sat?
Old Nov 18, 2003 | 10:35 AM
PM-Performance's Avatar
Default Re: axles and injectors on 2gen and 3gen tegs? (90teg)
they should fit , i have some on mine , and they should be saturated if im correct.
Old Nov 18, 2003 | 06:51 PM
emissionsux's Avatar
94-95 have saturated injectors.
Old Nov 19, 2003 | 02:49 AM
90teg's Avatar
Default Re: axles and injectors on 2gen and 3gen tegs? (emissionsux)
thanks for the info. so only 90-91 tegs have peak and hold?
Old Nov 19, 2003 | 02:56 AM
JDM_Honda_Fiend's Avatar
The axles should fit and as for the injectors:
All Acura/Honda's before 1992 use Peak & Hold style injectors. These are low resistance injectors that are measured at 2.5/3 ohms(measured at 43 P.S.I.G).
Acura/Honda's from 1992 and newer(with the exception of 92-96 Preludes) use Saturated injectors. These are high resistance injectors that are measured approx. at 12-16 ohms (measured at 43 P.S.I.G).
Cheers
Old Nov 19, 2003 | 05:08 AM
JBBNJ609's Avatar
Default Re: axles and injectors on 2gen and 3gen tegs? (JDM_Honda_Fiend)
honda accords use peak and hodl as well, i had a friend with a 4 door 94 accord EX (VTEC) and it had like 290cc peak and hold ones
92EGB16
Mar 2, 2010 10:55 AM
doodooheadfart
Feb 22, 2007 09:53 PM
integrx
Dec 4, 2003 12:57 AM
millertime
Dec 12, 2001 02:17 PM
