wheel offset and caliper clearance
Old Nov 18, 2003 | 09:39 AM
2000si's Avatar
Default wheel offset and caliper clearance
does anyone out there have a +45, +48, or +50 mm offset on their 00si. i just want to know if it will clear the caliper. i think that the factory offset is +45 so disregard that offset if the factory offset is +45. the reason i am asking is i need a 205 width tire to fit under the rear fenders and i need to know the correct offset to get. also the camber i have is set at zero not negative, so a negative camber to assist my getting the tires under the fender will not work.
any suggestions and help would be great
Old Nov 18, 2003 | 02:15 PM
2000si's Avatar
Default Re: wheel offset and caliper clearance (2000si)
ttt
Old Nov 18, 2003 | 02:59 PM
Evil_gambit's Avatar
I have a +42 offset and some 205/45's with no rubbing from the rear if that helps you. (its on a 98 ek)
Old Nov 19, 2003 | 09:32 AM
2000si's Avatar
Default Re: wheel offset and caliper clearance (Evil_gambit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil_gambit &raquo;</TD></TR><TR><TD CLASS="quote">I have a +42 offset and some 205/45's with no rubbing from the rear if that helps you. (its on a 98 ek)</TD></TR></TABLE>
do you have it lowered and if so how much and is the camber corrected on it????
my tires are sitting about .5 inches from the fender and my camber is zero degrees. with my other rims the offset was +45 with 195/55 and they tucked inside the fender...
the question i really have is will an offset of +45 with 205/40 sit under the fender with a zero degree camber adjustment ?????????/
Old Feb 3, 2006 | 08:40 PM
Squelch's Avatar
i am curious as well...
Old Feb 4, 2006 | 07:02 AM
UberMunkey's Avatar
if worrying about caliper clearence, it has less to do with offset, and more to do with the actual design of the wheel and it's spokes. you could have two different wheels of the same sizes and offsets, but one might not fit if has deeper or less curved spokes.
Old Feb 5, 2006 | 08:51 PM
Squelch's Avatar
Default Re: wheel offset and caliper clearance (factorviii)
don't mean 2 thread jack but i just want to make sure. im saving up for a tire/wheel upgrade within this year.
so even if you get a brembo or wilwood kit, clearance should be a problem whether ur running +42 or +45 wheels?
Old Feb 6, 2006 | 08:45 AM
UberMunkey's Avatar
well with those you would have to get a large enough wheel just to fit around the caliper. i imagine it has to be at least 16" on a big kit, probably larger. check with the manufacturer to be sure. other than that, there is no real good way to tell other than test fitting or finding out what other people with the same brake kits are running.
Old Feb 6, 2006 | 10:25 AM
Squelch's Avatar
Default Re: wheel offset and caliper clearance (UberMunkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UberMunkey &raquo;</TD></TR><TR><TD CLASS="quote">well with those you would have to get a large enough wheel just to fit around the caliper. i imagine it has to be at least 16" on a big kit, probably larger. check with the manufacturer to be sure. other than that, there is no real good way to tell other than test fitting or finding out what other people with the same brake kits are running. </TD></TR></TABLE>
i.
May 20, 2009 06:16 PM
sheperd77
Apr 25, 2009 10:13 AM
Halo
Dec 25, 2004 04:29 PM
spock_rocker
Feb 6, 2004 03:08 PM
jArceo
Oct 21, 2003 11:23 AM
