Another dumb question from me...Shift Linkage...95 del-sol
Im curious as to how to take off the shift linkage out of a 95 del-sol... i pretty much think I know exactly which pin to remove... but my buddy and i had a debate about this... so i need some insight.. and b4 12pm central time would be great...lol
Once again sorry for such a dumb question, I should be
but I rather ask questions then make mistakes and break things... that I have no money to replace lol. Thanx.
Well there is really only one pin to remove.. The rest are 12mm bolts! The shift linkage is a two part deal! If your only looking to get at the actual shifter, then all you need to do is undo the bolt that goes throughthe bottom of the shifter, that is what connects the shifter to the linkage to the tranny! Then undo the 12mm bolt that is connected to the tranny's side! This will allow that part of the linkage to come off the tranny! Then there are two bolts that hold a rubber piece by the shifter part itself! This holds the other portion! After taking out those two bolts, squeeze it by the exhaust, and voila... Shifter is out.... If that is what you are looking to do?
Ok, thanx. We got it that day anyways... I just figured it would be easier to ask honda-tech peepz since it moves so fast.
But nice write up. Thanx.
vtecpoweredsol
11
May 18, 2005 07:56 PM
