Question with oem wheels on new rubber
Old Nov 18, 2003 | 02:17 AM
swlabhot's Avatar
Default Question with oem wheels on new rubber
Anyone here use 225 50 15 on the stock ITR 15x6 wheels? Is the tire width too large that might cause any undesirable effects?
Old Nov 18, 2003 | 02:29 AM
ALLMOTR_R's Avatar
i stuck with 195 but 205 should be alright. 225 on 15x6, would not recommend, but what do i know!!!
PS, I got 265 on my 13x5 GSi. Psyche!!!
Old Nov 18, 2003 | 03:23 AM
jond's Avatar
Default Re: Question with oem wheels on new rubber (swlabhot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">Is the tire width too large that might cause any undesirable effects?</TD></TR></TABLE>
Some people complain 205's create a sloppy feel. 225 is way too much for a 6'' rim.
Old Nov 18, 2003 | 05:15 AM
1GreyTeg's Avatar
Default Re: Question with oem wheels on new rubber (jond)
At least one person runs 225/45 series tires on stock 6" wide rims in the RRAX forum so the point of them NOT fitting is moot. Too wide and sloppy can happen with 205/50's on 6" wide rims that run a bit wide like the Azenis Sports.
And the vague sloppy feeling for these is not a complaint, or personal opinion, it is truth. It has to do with the squareness of the tire sidewall to the wheel. It does affect turn in response, and simply going to a 7" wheel up front will cure this problem.
I run staggered 15x7" Kosei K1's up front and stock R wheels 15x6" in the rear with 205/50 Azenis and have no more steering feel/turn in issues. I also Run 225/45's on 7" rims for R compounds and while they fit fine, do rub the front wheel well liners and rear LCA's a bit.
Old Nov 18, 2003 | 06:25 AM
nw98typer's Avatar
225/50-15 is the common size for the front tires while autocrossing. Yes, they will fit, but you'll need spacers to give you clearance to the suspension and inner fender to prevent rubbing. 225's with spacers will cause the outside of the tire to be flush or a little outside of the fender opening.
When I've used the autocross tires to get me back and forth from the track, the car is a lot more sensitive to the ruts in the freeway lanes.
I personally, would not use 225's for daily use.
Old Nov 18, 2003 | 06:39 AM
Bbasso's Avatar
205 was too sloppy for me, I picked up a wider rim for the 205 and it felt good again.
Old Nov 18, 2003 | 06:51 AM
1GreyTeg's Avatar
Default Re: Question with oem wheels on new rubber (nw98typer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nw98typer &raquo;</TD></TR><TR><TD CLASS="quote">225/50-15 is the common size for the front tires while autocrossing. Yes, they will fit, but you'll need spacers to give you clearance to the suspension and inner fender to prevent rubbing. 225's with spacers will cause the outside of the tire to be flush or a little outside of the fender opening.
I personally, would not use 225's for daily use.</TD></TR></TABLE>
Offset decides if you require spacers or not and how the wheel/tire sits inside or outside the line of the fender.
225/45's don't rub so much that it is a major issue even with a +43 offset and only really rub lock to lock which you really shouldn't be driving anyway.
Old Nov 18, 2003 | 07:22 AM
nw98typer's Avatar
Default Re: Question with oem wheels on new rubber (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">
225/45's don't rub so much that it is a major issue even with a +43 offset and only really rub lock to lock which you really shouldn't be driving anyway.</TD></TR></TABLE>
Agreed.
However, the question was asked regarding the stock ITR wheels, which have a +50mm offset.
When autocrossing I use 225/50 with 5mm spacers and Millenia wheels. Since the Millenia rims are +50mm also, adding the 5mm spacer get's me close to the +43mm offset you mentioned, and reduces the rubbing.
I added the note about where the wheels sit as info so they can understand what it'll look like. Personally, I think they make the whole car look angry, which helps to intimidate my competition.
EF_ST@TUS
Sep 28, 2006 08:37 AM
01itr320
Honda S2000
May 28, 2005 10:36 AM
Bbasso
Oct 14, 2003 04:06 PM
E Swift
Aug 23, 2003 08:20 PM
4doorH22
11
Oct 3, 2001 04:36 PM
