Crane/Ferrea roller followers
Old Nov 18, 2003 | 12:03 AM
92 civic VX B18c's Avatar
HT Black Ops
Default Crane/Ferrea roller followers
Has anyone used or heard anything about these? They sure look nice! http://www.cranecams.com/import/hvteccomps.htm
Old Nov 18, 2003 | 08:03 AM
HT Black Ops
Default Re: Crane/Ferrea roller followers (92 civic VX B18c)
I can't help but notice that they say you can't use these with stock cams, I was wondering if they are alright to use with Skunk2 stage2's?
Old Nov 18, 2003 | 09:29 AM
tgreaves's Avatar
Most aftermarket companies dont have the technology to build a vtec setup.. I wouldnt trust them to try and mirror hondas design..
Old Nov 18, 2003 | 09:38 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: Crane/Ferrea roller followers (tgreaves)
how are they trying to "mirror" hondas design with a roller setup?
Old Nov 18, 2003 | 09:46 AM
SYD's Avatar
SYD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 civic VX B18c &raquo;</TD></TR><TR><TD CLASS="quote">I can't help but notice that they say you can't use these with stock cams, I was wondering if they are alright to use with Skunk2 stage2's?</TD></TR></TABLE>
ive herd of a people using the skunk2 stage 3s with these..dont know if i would try it but i know they have done it..maybe they grided down the 1st and secondary lobes?..or maybe they didnt have to? ..oh well i would just use the roller cams i guess ?
Old Nov 18, 2003 | 09:56 AM
tgreaves's Avatar
Default Re: Crane/Ferrea roller followers (bruceleeroy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruceleeroy &raquo;</TD></TR><TR><TD CLASS="quote">how are they trying to "mirror" hondas design with a roller setup?</TD></TR></TABLE>
They are using completly different rocker arms which is where most of the vtec system is.. As far as the vtec pins locking and unlocking the rockers..
Old Nov 18, 2003 | 10:03 AM
SYD's Avatar
SYD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">
They are using completly different rocker arms which is where most of the vtec system is.. As far as the vtec pins locking and unlocking the rockers.. </TD></TR></TABLE>
sorry your answer isnt making any sense to me
Old Nov 18, 2003 | 10:08 AM
SYD's Avatar
SYD
They are using completly different rocker arms which is where most of the vtec system is.. As far as the vtec pins locking and unlocking the rockers.. ..</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Most aftermarket companies dont have the technology to build a vtec setup.. I wouldnt trust them to try and mirror hondas design..</TD></TR></TABLE>
there isnt supposed to be locking pins for vtec the rollers are made to eliminate vtec (basically vtec engaged all the time) thats why u use "vtec killer" roller cams with these....and there mirroring hondas design how?
Old Nov 18, 2003 | 10:17 AM
tgreaves's Avatar
Ahhh.. Didnt know that is eliminated the vtec setup all together.. I thought this was a roller rocker vtec setup that they were selling.. My mistake..
Old Nov 18, 2003 | 10:19 AM
SYD's Avatar
SYD
thats what i started to realize...it would be nice if someone did make one though..u think? or do they?
Old Nov 18, 2003 | 10:22 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruceleeroy &raquo;</TD></TR><TR><TD CLASS="quote">thats what i started to realize...it would be nice if someone did make one though..u think? or do they?</TD></TR></TABLE>
I've never seen one out there if they do.. Would cut down on alot of drag in the valvetrain though..
Old Nov 18, 2003 | 10:23 AM
tgreaves's Avatar
So i guess these things just convert your b-series dohc vtec head into a high flowing ZC head then..
Old Nov 18, 2003 | 10:30 AM
SYD's Avatar
SYD
well dont the zc and ls have those "ball joint" type rockers?..i would imagine they arent as safe or stable at 9000 rpm and up then the "shaft" vtec rockers..oh well maybe im wrong?
Old Nov 18, 2003 | 10:33 AM
tgreaves's Avatar
Not sure what you mean by ball-joint.. I was refering to the fact that they turn you b series head into a dohc non-vtec like the ZC head but flows alot better then the ZC head.. I wonder how crappy the idle would be with this setup..
Old Nov 18, 2003 | 10:35 AM
SYD's Avatar
SYD
sorry i wasnt more clear...what i ment is u see how the rockers in a ls or zc head basically are secure by the rocker just sitting on a ball joint and the cam lobe as to the vtec rockers are secure with a shaft.
Old Nov 18, 2003 | 10:36 AM
SYD's Avatar
SYD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">.. I wonder how crappy the idle would be with this setup.. </TD></TR></TABLE>
its very lopey!
Old Nov 18, 2003 | 01:41 PM
Stew Pidasso's Avatar
I have to wonder why my H22A doesn't have roller rockers. My F22B1 has roller rockers...
Old Nov 18, 2003 | 02:00 PM
func-tion's Avatar
There are a few other post on this board asking the same question and nobody seems to know anything of them. Too expensive of an upgrade I guess.
From what I understand they kinda work off the same principal as todas vtec killer camshaft kit. EXCEPT the cranes ride on the vtec lobe while to todas ride on the primaries.
If you looking to lose weight. Spoon made/makes a lightweight follower kit for the b-series. But like most spoon parts they are pretty much warmed over stock pieces that are a little lighter, maby stonger and cost mucho $,$$$.$$.
Junkyard2000
Sep 28, 2005 10:03 PM
cal25
Jan 20, 2005 04:46 PM
NathanMorris
Dec 20, 2004 10:03 PM
VSBB6
Sep 27, 2004 10:58 AM
1hotintegra
11
Jun 17, 2003 12:30 PM
