Slicks and Rims Size Questions... did search
Im looking to get some M&H 24.5x8.5x15 slicks, or somewhere along that size, whats the smallest possible width rim can those things mount on? would they fit on a 15x6.5 size rim?
JohnM&H: would u care to chime in and tell me what availabe sizes u have or coming out with for the 15" rims? thanx in advance!
general rule of thumb the biggest you should go would be a 1 inch differance from wheel width to slick width.....
although i do have a 10.5 inch slick on an 8 inch wheel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboDANDEE »</TD></TR><TR><TD CLASS="quote">Im looking to get some M&H 24.5x8.5x15 slicks, or somewhere along that size, whats the smallest possible width rim can those things mount on? would they fit on a 15x6.5 size rim?
Well (TurboDANDEE) The 8.5/24.5-15 needs a 8"rim size that is what M&H req's now by usesing a 6.5" you are going to push the slick in more and it will cause a crown in the center and you will lose some of the contact patch. I would atleast go with a 7" or better. I hope this helps.
John@M&H-Hashim's
</TD></TR></TABLE>Well (TurboDANDEE) The 8.5/24.5-15 needs a 8"rim size that is what M&H req's now by usesing a 6.5" you are going to push the slick in more and it will cause a crown in the center and you will lose some of the contact patch. I would atleast go with a 7" or better. I hope this helps.
John@M&H-Hashim's
