dom and erw donkeysh*t
Old Nov 17, 2003 | 09:21 PM
tegasaurus's Avatar
Default dom and erw donkeysh*t
Does it matter if your cage is erw or dom if your car runs an 11.99 or faster?
considering this is taken from the 2003 NHRA handbook, it says nothing about dom and ERW construstion, so long as it:
is constructed of minimum 1 ¾ inch o.d. x .118 inch wall mild steel tubing, or 1 ¾ x .083 chrome moly tubing, and must conform to the following diagram:
The autopower 6pt "cage" is made of 1.75 od and .120 inch wall mild steel. so it should be legal to run my car which, theoretically, is capable of 11 second passes. yes?
-Ryan
P.S. im too lazy to search any more, i couldn't find a straight answer on the first 3 pages of results so i decided to post.
Old Nov 18, 2003 | 06:19 AM
earl's Avatar
Default Re: dom and erw donkeysh*t (tegasaurus)
How is it installed?
Old Nov 18, 2003 | 06:21 AM
DaveF's Avatar
Default Re: dom and erw donkeysh*t (earl)
it needs to be welded in correct?
Old Nov 18, 2003 | 06:34 AM
PM-Performance's Avatar
Default Re: dom and erw donkeysh*t (2.2Lcivic)
I believe it says something in there about being welded in bt like 1/4" steel plates. soemthing to that effect.
what is the breakoff as to when you need a full cage? is it 135mph?
Old Nov 18, 2003 | 11:36 AM
1fstcorrado's Avatar
cage can be bolted in with 6 inch plates....as long as there are 6" back up plates underneath....i(all plates 1/8" thick)t says nothing about how big the plates have to be if they are welded in so long as they are welded to the factory rocker sill.
P.S. laziness will get you know where.......just show's at how easy it is for you to give up. its all good
Old Nov 18, 2003 | 12:30 PM
tegasaurus's Avatar
Default Re: dom and erw donkeysh*t (1fstcorrado)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fstcorrado &raquo;</TD></TR><TR><TD CLASS="quote">
P.S. laziness will get you know where.......just show's at how easy it is for you to give up. its all good</TD></TR></TABLE>
WHO THE F^CK do you think you are?
Old Nov 18, 2003 | 01:16 PM
El_Jefe's Avatar
dude, calm down, and NO autopower cages ARE NOT LEGAL, they are bolted together, ie. the 2 back backs are bolted to the main loop = not legal
the cage has to be all welded together, but may be bolted to the car with backing plates.
Old Nov 18, 2003 | 01:55 PM
tegasaurus's Avatar
Default Re: dom and erw donkeysh*t (El_Jefe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El_Jefe &raquo;</TD></TR><TR><TD CLASS="quote">dude, calm down, and NO autopower cages ARE NOT LEGAL, they are bolted together, ie. the 2 back backs are bolted to the main loop = not legal
the cage has to be all welded together, but may be bolted to the car with backing plates. </TD></TR></TABLE>
sorry, i do get carried away, but i find that to be the most crude and demeaning thing i have read on honda-tech in the past several months. Thank you for So you're 100% sure i wouldn't be able to get past tech with that cage to run 11s?
thx,
ryan
Old Nov 18, 2003 | 03:06 PM
SadisticRacing's Avatar
El jefe is a tech at the local my local track, I would go with what he says!!
Old Nov 18, 2003 | 03:20 PM
This One's Avatar
Default Re: dom and erw donkeysh*t (SadisticRacing)
DOM is the mandated requirement for NHRA i beleive, i dont know the others
But if the requirements aren't made for you car ERW is acceptable if you go to the next biggest size in material that is listed for your application
Old Nov 18, 2003 | 04:55 PM
tegasaurus's Avatar
Default Re: dom and erw donkeysh*t (tHIS oNE)
el_jefe
according to the picture i pulled form the NHRA handbook webpage, can that little "arm" that extends along the driver side be collapsable? like can that be bolted in or not?
-Ryan
Old Nov 19, 2003 | 07:09 AM
yes it can be a swing out bar. about the jab, did not think you would take it the wrong way...........
Old Nov 19, 2003 | 03:49 PM
Jared's Avatar
Not 100% sure, but I think the 6 point cage gets you to 9.99 with no issues.
Old Nov 19, 2003 | 04:26 PM
Tofurky's Avatar
that guy can't be too comfortable with that rod going up his anus.
Old Nov 19, 2003 | 08:25 PM
tegasaurus's Avatar
Default Re: dom and erw donkeysh*t (Tofurky)
haha
Old Nov 24, 2003 | 11:24 AM
tegasaurus's Avatar
lol @ know where hahaha
Old Nov 24, 2003 | 01:26 PM
I'm busted, oh well........i cant believe it took you 6 days to catch that...
sanman000719
Jan 5, 2009 05:19 AM
zexxbo
Welding / Fabrication
15
Nov 18, 2007 07:13 AM
NinetyTwoHB
10
Feb 26, 2005 06:13 AM
tommyten
Feb 19, 2005 09:15 AM
advanracing62
10
Apr 2, 2003 07:53 AM
