automatic or manual p28?
you will know as soon as you plug it in. you will throw CEL if your cars i 5 speed and it is a auto ecu. and if your car is auto and the ecu is a 5 speed your car wont change gears.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedemon »</TD></TR><TR><TD CLASS="quote">how else can you tell other than by actually pluging it in?</TD></TR></TABLE>
it is not hard to plug it in. all you do is well...ummm....plug it in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedemon »</TD></TR><TR><TD CLASS="quote">I can't really see the difference in those pics does neone have a better one
Look at the small pictures underneath them...they are diff. (hint look at the right end of them)
If it is a P28-A00, A01, A02, L00, L01 or L02, it is a manual ECU. If it is a P28-A50, A51, A52, L50, L51, or L52 it is automatic. If you need a manual ECU, and yours is an auto, it can be converted to manual. Look here: http://www.hondata.com/downloa...l.doc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
Look at the small pictures underneath them...they are diff. (hint look at the right end of them)</TD></TR></TABLE>
...and judging by the pictures you should be able to convert one to the other fairly easily.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">
...and judging by the pictures you should be able to convert one to the other fairly easily.</TD></TR></TABLE>
Auto to manual isn't hard but the manual doesn't have the two fets required to operate the shift solinoids on an auto car, so manual to auto is much harder.
SOHC_Brian
16
Feb 25, 2004 08:47 PM
