can i put 4300k bulbs in my 6000k hid kit?
Old Nov 17, 2003 | 07:46 PM
slowacura's Avatar
Default can i put 4300k bulbs in my 6000k hid kit?
hid bulbs can just be swtitched, right? i have a 6000k phillips hid kit but it's a little too blue - i can tell i'm not getting the right color light. i want to try a different bulb but want to make sure it works
Old Nov 17, 2003 | 07:49 PM
Mandeep's Avatar
wrong
integraL's Avatar
Default Re: (Mandeep)
maybe you shouldve gotten the 5000k...i heard that one isnt too bad
Old Nov 17, 2003 | 09:45 PM
-1TSXer-'s Avatar
Default Re: can i put 4300k bulbs in my 6000k hid kit? (inteGSR)
I believe each ballast is rated for the particular capsule application. Meaning you can't interchange capsules of different color temps.
Old Nov 17, 2003 | 11:05 PM
Slain's Avatar
you can change as long as the base is the same.
Old Nov 18, 2003 | 01:45 AM
Dra6on45's Avatar
u can change it as long as the new bulbs fit the plug
Old Nov 18, 2003 | 05:56 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: can i put 4300k bulbs in my 6000k hid kit? (-CivicTuner-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -CivicTuner- &raquo;</TD></TR><TR><TD CLASS="quote">I believe each ballast is rated for the particular capsule application. Meaning you can't interchange capsules of different color temps.</TD></TR></TABLE>
Nope, ballast does nothing but ignite and sustain the arc in the bulb. Of course you can change bulbs as long as the base is the same. You can put 6000K and even higher ricer HID bulbs in cars that came w/ OEM HID.
Old Nov 18, 2003 | 06:57 AM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Default Re: can i put 4300k bulbs in my 6000k hid kit? (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
Nope, ballast does nothing but ignite and sustain the arc in the bulb. Of course you can change bulbs as long as the base is the same. You can put 6000K and even higher ricer HID bulbs in cars that came w/ OEM HID.</TD></TR></TABLE>
Beat me too it!
chatman_55
Nov 30, 2008 11:24 PM
rainmanef
Lighting
Jul 10, 2008 05:26 PM
krazyhmongboi
Lighting
Sep 12, 2007 11:51 AM
skingfreak
Jan 29, 2007 06:30 PM
ThaReal24k
Apr 28, 2005 08:11 PM
