4Th gen lude...wont start...i think i made a bad oopsie!
Ok...so its 4am..and i was falling asleep as i was installing my fuel rail.Turns out my rewired injector harness(to adapt to obd2) had some wires exposed.I believed right when it was time to check for leaks...i turned the key to the on position.From there i was getting no fuel,my vafc doesnt light up...and i checked for spark.NONE.I've checked all underhood and underdash fuses.Im lacking sleep and need some help.PLEASE!!!Anyone?I've tried a different ecu too.Nuthin.So fuses/ecu checked....car will try to crank but does not make any spark or release any fuel.I dont hear my fuel pump turning on.Please...someone help!?Thanks...
Mikey
Mikey
true, sounds like your main battery fuse may even be killed. what about your hazard @ ecu relay? sounds like your ECU isnt powering up since it controls everything and the afc is tapped into the ecu's power source.
[Modified by Jared, 12:13 AM 9/13/2001]
yeah....i've checked everything besides my main relay.Its a pain in the *** tryin to find it right now...do you fella's know if its located in the same spot as 92-up civic's?Cuz im reaching far up there and cant find anything in the jungle of wires.But i truly appreciate the feedback and help!THANKS!!
