Master Cylinder/Brake fade
I have a 90 honda accord lx 4 door auto. Anyway when I come to a stop at a light and hold the brake if I keep constant pressure the brake will release and the car will move forward unless I push the pedal down more. My concern is that I either have a leak in the brake system somewhere or else the master cylinder is shot. Any ideas? The car is very old now and has seen lots of action has alomost 200k miles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lonefuzzy79 »</TD></TR><TR><TD CLASS="quote">I have a 90 honda accord lx 4 door auto. Anyway when I come to a stop at a light and hold the brake if I keep constant pressure the brake will release and the car will move forward unless I push the pedal down more. My concern is that I either have a leak in the brake system somewhere or else the master cylinder is shot. Any ideas? The car is very old now and has seen lots of action has alomost 200k miles. </TD></TR></TABLE>
Sound like you either have a leak in the brake system somewhere or else the master cylinder is shot.
But you knew that allready.
dont guess it, test it.
key not in your car, pump the brake panel about 10 times and dont release it, turn the key and start the car, see if the brake panel slowly drift down toward the floor(about 1inch drops)
a working brake booster will
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotaryBzzzz »</TD></TR><TR><TD CLASS="quote">for brake parts like MC's, buy only new not rebuilt....and preferably oem if po$$ible.
Worth every penny.</TD></TR></TABLE>
Couldn't agree with you more! I made that mistake (rebuilt aftermarket) when I did mine.... MC didn't release all the way, brakes drag, all 4 wheels locked up after several miles...talk about a major PITA!
if you are gonna buy a new MC
try to find the official part number of the OEM part and try http://www.hparts.com (or request for a quote). My 5th gen one is listed as $75 for a new oem MC, too bad I paid $100 for it somewhere else before I checked the price there.
try
46100-SM4-A04
if you do plan to replace it, and you dont have 4 wheel disc/ABS, u can consider getting the larger ABS MC.
Modified by TypeSH at 4:01 AM 11/18/2003
try
46100-SM4-A04
i have a problem of time to time my brakes feel liek grabing at times it dont ...
what i did so far...new MC, bleeded the system 3 times or so, brake pads good,rotors good, and was told calipers are good..what can it be Booster ?
1995 accord with h22a..and have a new accord M C should i buy prelude or an ex MC ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Showoff »</TD></TR><TR><TD CLASS="quote">i have a problem of time to time my brakes feel liek grabing at times it dont ...
1995 accord with h22a..and have a new accord M C should i buy prelude or an ex MC ?</TD></TR></TABLE>
do a booster check, it might be the seal on the wheel cylinders, it could be a external leak as well as an internal leaks
"if you do plan to replace it, and you dont have 4 wheel disc/ABS, u can consider getting the larger ABS MC."
with a larger MC piston surface you are only getting less distance down at the wheel cylinder, you dont just add a bigger mc with bigger piston to increase braking power
sobey
Mar 11, 2009 06:08 PM
