hid fittings
does any know if its possible to get a 9006 hid kit to fit a h4 headlamp my friend is selling them cheap and i want to know if i could get them to fit mine. what i need to know is can i get it to fit and how much x tra will it cost and whats the labor time look like
anything is possible with a little work. May require the use of an exacto knife, some silicone sealant and a bit of creativity. You're looking at an install time of about an hour. Shouldn't cost you anything extra if you d
o it yourself
o it yourself
Carefully remove all the tabs around the base of the Bulb (cutting them off). Get a a pair of H4 adapters. some sort of sealant/glue and glue the H4 adapters on and they should work. there you go. also i recommend casper shields to get a acurate beam pattern
CrazyHondaBoy
Dec 7, 2002 09:02 AM
