How do I check codes during check engine light?
Old Nov 17, 2003 | 02:52 PM
ErikDaGenErik's Avatar
Default How do I check codes during check engine light?
sorry if this is a newbie question, but i have a check engine light in the morning when my b18c is really cold. after warming up the engine for 5 minutes, i turn the car off, and then on again......then the light goes away.
i did a search on this already and i found a link to hondata's site that tells you about the codes, but i can't find that blue wire connecting thingy where i can stick the paperclip in. all i know is that its on the passenger's side near center console. if anyone has a pic or can give me a more precise location, i would appreciate it. thx
Old Nov 17, 2003 | 03:00 PM
Steve04SVT's Avatar
Default Re: How do I check codes during check engine light? (ErikDaGenErik)
You're in the vicinity. It's on the passenger side right under the glove compartment. You'll probably need to look under there to see it. It's a blue connector with two wires, and should have a green rubber cover over it.
Old Nov 17, 2003 | 05:42 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If the ECU is OBD2 then I think you need a scanner to get the codes.
Old Nov 18, 2003 | 12:10 AM
Default Re: How do I check codes during check engine light? (PatrickGSR94)
its been converted to obd1
Old Nov 18, 2003 | 12:19 AM
integraL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">If the ECU is OBD2 then I think you need a scanner to get the codes.</TD></TR></TABLE>
? - i have obd2 and i jumped it normally
DavidRai
Aug 4, 2018 02:10 PM
jalow69
Dec 2, 2005 07:34 AM
log1c
May 5, 2005 07:36 PM
integraautox
Oct 24, 2002 09:21 PM
mr poo
Aug 15, 2002 11:01 AM
