JDM ITR Transmission...
I have a 2000 JDM type R transmission I baught off of a local parts shop, and I am having my doubts of it being a true JDM type r transmission, the transmission has a lsd for sure and says S80 on it. I am a little sceptical on them. So since I am not going to install it for a while I was thinking of taking it apart to count the teeth on the gears. But the only thing is I forgot how many teeth are supposed to be on them for it to be a true JDM type R transmission. If you could help it would be great!
if you look at the tranny housing where usdm says J4Dor JH4 LSD if its jdm it will say LSD N3E if its a 98 spec+ jdm tranny that will be the deciding factor if its a true 4.7 jdm tranny
Modified by gsr-2nr at 10:25 AM 11/18/2003
first of all thanks for that insightful information...
and to the guy above him i know that part i need to know by counting the gears , so does anyone know how many splines there are?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr-2nr »</TD></TR><TR><TD CLASS="quote">if you look at the tranny housing where usdm says J4Dor JH4 LSD if its jdm it will say LSD H3E if its a 98 spec+ jdm tranny that will be the deciding factor if its a true 4.7 jdm tranny</TD></TR></TABLE>
Good notes, only issue is that those are painted on, and can come off with cleaning/wear(hth you'd were there... who knows). S80 is the designation for a 98+ jdm spec tranny also, at least it is on mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">
Good notes, only issue is that those are painted on, and can come off with cleaning/wear(hth you'd were there... who knows). S80 is the designation for a 98+ jdm spec tranny also, at least it is on mine.</TD></TR></TABLE>
S80 also comes on gsr's also just minus the lsd so i dont know if is the designation for a jdm tranny. if the lsd n3e is still on there that will be the confirmation he needs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">Oh and did a quick search for the jdm final drive ("teeth jdm fd").
"14
and 67 and the big one..."</TD></TR></TABLE>
can you maybe clear that up a lil ?
"14
if you take the axles out and look into the diff you can tell. IF you can see straight through it has the LSD, if there's alittle bar inside you don't.
I had the same worries on my JDM type r motro, because teh LSD stamp was washed off....
"14
Um, there are two sets of teethed area on the FD, confirm those teeth numbers and you have a 4.785 final drive.
"14
civicdohc
Apr 18, 2002 01:38 PM
SPOON_BeIgHtEeNsEe
Dec 27, 2001 03:23 PM
