Are vtec and non-vtec Throttle bodies interchangable?
Old Nov 17, 2003 | 11:44 AM
Propulsion's Avatar
Default Are vtec and non-vtec Throttle bodies interchangable?
For instance, could I take a b20 TB and put it on a b16 Intake manifold? Any modifications required?
Old Nov 17, 2003 | 01:13 PM
Propulsion's Avatar
Default Re: Are vtec and non-vtec Throttle bodies interchangable? (SilverCIVIC96)
anyone know?
Old Nov 17, 2003 | 01:31 PM
non-VTEC's Avatar
they should work.
as long as the B16 is OBD2 (96 and up) cuz i do belive honda remove the fast idle thermo valve thingy from under the T/B in 96 and up.......
how this helps.......
Old Nov 17, 2003 | 02:01 PM
Propulsion's Avatar
Default Re: Are vtec and non-vtec Throttle bodies interchangable? (non-VTEC)
thanks, could anyone say for sure?
Old Nov 17, 2003 | 05:10 PM
Propulsion's Avatar
up
Old Nov 17, 2003 | 05:51 PM
civicguy's Avatar
they do work
Old Nov 17, 2003 | 06:16 PM
mmuller's Avatar
Mad Scientist
Default Re: (civicguy)
if the b16 is 1st gen a throttle body with the fitv in the bottom wont work. but obd2 will
Old Nov 18, 2003 | 09:35 AM
tgreaves's Avatar
Im running a B16(vtec) throttle body on my D15B7(non-vtec) and it works fine.. Had to port the intake manifold out a little bit but the bolt holes all lined up fine..
Mr.DC2TurBo
Mar 22, 2010 04:21 PM
Nicaraguense13
Feb 28, 2007 12:36 PM
lmiguelvv
31
Aug 29, 2005 05:25 PM
jdmCivic925
Aug 6, 2004 11:34 PM
