1995 accord ex ABS dummy light
Old Nov 17, 2003 | 10:13 AM
vtec4gcivic's Avatar
Default 1995 accord ex ABS dummy light
Any way to tell why the ABS light is on? I just changes passanger-side rotor caliper and brakes..Now the ABS light is on. ABS resevoir is full of brake fluid..Not sure what to do next!! ANY IDEAS???????
Karl
Old Nov 17, 2003 | 11:14 AM
RotaryBzzzz's Avatar
Default Re: 1995 accord ex ABS dummy light (vtec4gcivic)
you need to pull some codes and/or clear codes. see my sig. Probably you need to bleed the abs system.
Old Nov 17, 2003 | 01:28 PM
fw190bvi's Avatar
dude.....mines the same way....but my abs is shot.....on the 94 accord, theres a number of possible codes dealing w/ the abs light, but u can only check one at a time (later models can chekc for multiple).....so its practically impossible to diagnose.....if u know ur abs is still working, i wouldnt really worry about it, but if its not.....about the only thing u can do is replace ur abs, or unhook the fuse to that light....also....can u hear ur ABS pump running for a few min after u turn on teh ign?????
Old Nov 17, 2003 | 03:04 PM
Neldawg's Avatar
Default Re: 1995 accord ex ABS dummy light (RotaryBzzzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotaryBzzzz &raquo;</TD></TR><TR><TD CLASS="quote">you need to pull some codes and/or clear codes. see my sig. Probably you need to bleed the abs system.</TD></TR></TABLE>
Sup
I just got a code on my 96 Accord for the ABS and its a 32.....
Looked up the code and its says its the "Front Left Pulsar" Any ideas on how to fix that??
I really don't know what that is...
Thanks
Old Nov 17, 2003 | 04:08 PM
Stew Pidasso's Avatar
Default Re: 1995 accord ex ABS dummy light (Neldawg)
Try cleaning the wheel sensor, reset the code and see if it comes back.
Edit: Just spray some brake cleaner in there. Follow the single wire on your upper control arm to where it meets the cv joint. You will see a notched metal ring around the cv boot. Make sure there is no grease/dirt on it and spray the brake cleaner where the sensor meets this ring...
Old Nov 17, 2003 | 04:21 PM
Default Re: 1995 accord ex ABS dummy light (Stew Pidasso)
are u talking about the sensor that is magnet that bolts up with two 12mm bolts the the rotor assembly?right next the axle?
Old Nov 17, 2003 | 04:35 PM
mwkirchner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neldawg &raquo;</TD></TR><TR><TD CLASS="quote">
Sup
Looked up the code and its says its the <FONT COLOR="red">"Front Left Pulsar"</FONT> Any ideas on how to fix that??
Thanks</TD></TR></TABLE>
The pulsar is the ring that is around the outer cv joint. You should look it over and be sure none of the raised areas have any nicks in them. That is one thing that will cause it to give off that reading.
Old Nov 17, 2003 | 04:36 PM
Default Re: 1995 accord ex ABS dummy light (mwkirchner)
Yes that's it.
Old Nov 17, 2003 | 04:40 PM
Neldawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec4gcivic &raquo;</TD></TR><TR><TD CLASS="quote">are u talking about the sensor that is magnet that bolts up with two 12mm bolts the the rotor assembly?right next the axle? </TD></TR></TABLE>
You should find out what the code is first .....You check it the same way you would check your CEL (Check Engine Light). Look under your glove box for a blue plug with a 2 wire setup. Then after you find that you take a paper clip and connect the 2 wires by loopin the paper clip thru the 2 holes from the socket. Then turn on your car to the accessory switch on the igition. Your ABS light will flash in a specific sequence which will tell you the code. For Example. My light blinked 3 times then paused....then it blinked 2 times.... then it was a longer pause and it started over again....So the code was 32 for my vehicle.
See what code you get and post it ....i'm sure someone will answer it.
If not just take it into Autozone or one of those shops and have them scan it
Old Nov 17, 2003 | 04:43 PM
i dont understand what u are referring to as the outer ring of the cv axle? I wish u had some pictures
Old Nov 17, 2003 | 04:44 PM
Neldawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mwkirchner &raquo;</TD></TR><TR><TD CLASS="quote">
The pulsar is the ring that is around the outer cv joint. You should look it over and be sure none of the raised areas have any nicks in them. That is one thing that will cause it to give off that reading.</TD></TR></TABLE>
So the Pulsar is just a ring??
hmm...
ok..thanks for the tip
I will check that out tomorrow.
Would there be anything else in that area that can cause that light to come on?
I might as well look for other problems while I am there in case there are no nicks in that area.
Thanks
Old Nov 17, 2003 | 04:54 PM
mwkirchner's Avatar
You can also try to check out the sensor itself.
The way you do that is to disconnect it at the connector before the sensor. With an OHM meter you want to probe the 2 terminals inside the connector. Put the positive on one terminal and the negative on the other. See if you get a reading. Now ... switch them around. You SHOULD get a reading one way ... BUT ... not the other. There is a diode in the sensor and that is why you will only get a reading in one direction. If you do get readings both ways ... replace the sensor.
Old Nov 17, 2003 | 04:58 PM
mwkirchner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec4gcivic &raquo;</TD></TR><TR><TD CLASS="quote">i dont understand what u are referring to as the outer ring of the cv axle? I wish u had some pictures </TD></TR></TABLE>
Old Nov 17, 2003 | 05:13 PM
Do u have a picture of the abs sensor as well just do i can make sure im cleaning the right part?
Old Nov 17, 2003 | 05:23 PM
mwkirchner's Avatar
This is a picture of an ABS sensor ... yours may not look exactly like this ... but it will be close. You will be able to see it mounted close to the ring on the outer cv joint.
Old Dec 1, 2003 | 05:52 AM
Thanks for your help, i havent got around to try and clean it yet..but im going to here soon
Old Dec 1, 2003 | 10:10 AM
The abs dummy light blinks a 42 code any idea what that is? it blinks four times then twice.
Thanks,
Karl
310HPS2k
Sep 25, 2005 06:09 AM
DubFat
Apr 15, 2005 10:04 PM
Shaun92lude
Dec 8, 2004 07:11 AM
aznballerz
Jun 16, 2004 02:21 PM
