a/c and power steering on gsr ek question
just got a gsr swap done like 2 weeks ago.
now i want to put on power steering and a/c.
i have the del sol vtec bracket on my motor right now...i was just wondering which a/c will work on it. my ek civic a/c compressor? or do a gsr a/c?
for my power steering, i have my ek power steering pump but i dont know what bracket to use. any gsr power steering bracket will work with my civic power steering pump? anyone know?
yes yes. i tried the search but all i could find is people asking what bracket to use for their a/c and i know its the del sol vtec and i have it. i need to know which a/c compressor i can use on it.
You need GS-R everything... brackets, rack, pump, compressor, and lines. You'll need an A/C evaporator core, and condesor as well. I have some of the A/C parts if you're interested, in addidion to a PS pump w/ aem pulley. Only parts I don't have for you is the P/S rack and A/C lines/compressor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quik Chris »</TD></TR><TR><TD CLASS="quote">You need GS-R everything... brackets, rack, pump, compressor, and lines. You'll need an A/C evaporator core, and condesor as well. I have some of the A/C parts if you're interested, in addidion to a PS pump w/ aem pulley. Only parts I don't have for you is the P/S rack and A/C lines/compressor. </TD></TR></TABLE>
i have all the stuff from my civic for the power steering and i have all the a/c stuff from my civic except for the compressor, i have a gsr a/c compressor..that wont hook up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BME1986 »</TD></TR><TR><TD CLASS="quote">so when you swap to saw a GSR or ITR motor, you won't have ps or a/c?</TD></TR></TABLE>
well..from what i heard for a/c, all u need is a del sol vtec bracket...but not sure which a/c components are needed...i have all the civic components and a gsr a/c compressor...
not sure about the p/s...i probably jsut need the gsr p/s bracket and just plug it in...we'll see..im going to try it this weekend..
the pullies don't line up for a D-series compressor on a B-Series motor. You need a GS-R compressor. You should be using the B-series A/C mount already for your front lower mount. Civic lines should work, you might have to bend them a bit. You need a B-series mount for power steering and b-series P/S pump. Civic power rack will work fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quik Chris »</TD></TR><TR><TD CLASS="quote">the pullies don't line up for a D-series compressor on a B-Series motor. You need a GS-R compressor. You should be using the B-series A/C mount already for your front lower mount. Civic lines should work, you might have to bend them a bit. You need a B-series mount for power steering and b-series P/S pump. Civic power rack will work fine. </TD></TR></TABLE>
thanks...
thanks...
EK SQUAD 425
Mar 26, 2006 04:55 PM
ciph3r
Apr 23, 2005 05:25 AM
