iving Iridium plugs: NGK or Denso ??
Old Nov 17, 2003 | 07:44 AM
iperez's Avatar
Default Iridium plugs: NGK or Denso ??
Guys, I need to buy some plugs soon. I've been putting this off way too long. Anyway, I noticed that NGK Iridiums cost about half of what Denso Iridiums cost. Does anyone know why this is ?? Are the Densos that much better over the NGKs or are the NGKs crap ?? I need to place my order for these plugs soon and I will appreciate your input...
BTW: On a 2001 mostly stock ITR, which part number plug should I buy ?? Thanks !
Old Nov 17, 2003 | 07:55 AM
Bbasso's Avatar
Default Re: Iridium plugs: NGK or Denso ?? (iperez)
I have the denso non-iridiums and they work fine. Usually I use Champion plugs for the street with no problems... 0.89 each
Old Nov 17, 2003 | 08:18 AM
ej1civic's Avatar
I say go with the stock NGKs man, and no they're not crap.
Old Nov 17, 2003 | 08:28 AM
TsunamiZC's Avatar
Default Re: Iridium plugs: NGK or Denso ?? (ej1civic)
Last time i changed the plugs i used the OEM part # for the Denso's .....Platinum ....i would have gotten the NGK's, but alot of stores dont carry them ....
Old Nov 17, 2003 | 09:28 AM
Opie's Avatar
Default Re: Iridium plugs: NGK or Denso ?? (tsunami_zc)
I run NGK iridium temp 7 plugs i noticed a better throttle response and a smoother idle when I swapped them in!
Hope that helps
Old Nov 17, 2003 | 09:39 AM
iperez's Avatar
Are we talking about Denso "IK20" iridium plugs ?? I want to make sure I order the right ones.
Opie, what is the part number on the NGKs ??
Old Nov 17, 2003 | 09:44 AM
Rhetoric's Avatar
Default Re: (iperez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iperez &raquo;</TD></TR><TR><TD CLASS="quote">Are we talking about Denso "IK20" iridium plugs ?? I want to make sure I order the right ones.
Opie, what is the part number on the NGKs ?? </TD></TR></TABLE>
BKR7E (6097) is what I found most people to be running. I used to run the R561A-7
Old Jan 21, 2004 | 03:15 PM
That Dood's Avatar
Default Re: (Rhetoric)
back up....I just ordered smoe of the NGK bkr7eix-11 and they are $6 each. Good price for an iridium plug...
Old Jan 22, 2004 | 05:39 AM
iperez's Avatar
Here's a comeback on this topic ... After all the research, I went with the Denso Iridiums for just under $50 delivered from an Ebay shop. I can say I am very happy with them so far. The car starts nicely and there is a "seat of the pants" feeling that the car is a little more torquier. So, I'm happy.
Here's a side-note.. My brother-in-law bought the NGK Iridium counterparts for about $20 less than I paid for the Densos. The results on his car are basically identical to what I experienced on my ITR. The plugs look almost identical. All in all, it looks like I would have gotten the same results with the NGKs and saved a few bucks.
Old Jan 22, 2004 | 12:25 PM
That Dood's Avatar
I am gonan go throw them in....I have some old 10k probaly coppers and a 40k mile dist cap and rotor...throwing in the NGK 7's and new cap and rotor....picked it all up for $39....for a Yec(instead of TEC) dist cap and rotor...
Old Jan 22, 2004 | 01:00 PM
mstewar's Avatar
any rec's on the cheapest place to pick up the NGKs?
Aren't OEM NGKs temp 6? What does running the 7's get you?
Old Jan 22, 2004 | 02:12 PM
That Dood's Avatar
Default Re: (mstewar)
nniiiicccceee....
Old Jan 22, 2004 | 04:09 PM
JDM23's Avatar
I think the difference in price is because the NGK's are just coated with iridium and the Denso's are full iridium. I have the Denso's in my car and love them....
Old Jan 23, 2004 | 08:39 AM
That Dood's Avatar
Default Re: (JDM23)
dood the NGKs are solid iridium....and this setup is BAD...better than stock....
Old Jan 23, 2004 | 10:47 AM
98cwitr's Avatar
im using denso iridiums, no complaints
Old Apr 26, 2007 | 04:16 PM
Agent_EM1's Avatar
NGK Iridium yo!
Old Apr 26, 2007 | 04:23 PM
neo_'s Avatar
Default Re: Iridium plugs: NGK or Denso ?? (Agent_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">NGK Iridium yo!</TD></TR></TABLE>
Whats the point of bumping a 2 year old thread for a comment like that?
Old Apr 26, 2007 | 08:02 PM
Jason.'s Avatar
Default Re: Iridium plugs: NGK or Denso ?? (neo_)
Wow, great, nice...
Old Apr 27, 2007 | 04:24 AM
Petah's Avatar
Default Re: Iridium plugs: NGK or Denso ?? (Jason.)
I don't see the point in running pricey plugs. I just use NGK copper (best conductor) and change it out every season.
Old Apr 27, 2007 | 06:11 AM
iperez's Avatar
Holy back from the dead thread Batman !! hehe ..
FWIW: After this thread, I went and bought Denso Iridiums for the R. I'm now making 206WHP on my NA build and the Iridiums are still there. My butt-dyno likes them and they seem to last forever. Good stuff.
Old Apr 27, 2007 | 08:24 AM
EARLdaSQUIRREL's Avatar
official honda whore
FWIW i use ngk bkr7e (regular kind) and change them every other oil change... they work great and are cheap (under 10 bucks for all 4)
Old Apr 27, 2007 | 08:32 AM
rcar97's Avatar
Default Re: Iridium plugs: NGK or Denso ?? (Petah)
Old Apr 27, 2007 | 08:37 AM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Petah &raquo;</TD></TR><TR><TD CLASS="quote">I don't see the point in running pricey plugs. I just use NGK copper (best conductor) and change it out every season. </TD></TR></TABLE>
Depends on you personally. You can run cheaper plugs and change them faster, or run expensive plugs and change them less.
It's like the Syn oil vs. conv. oil. You'll end up spending close to the same, just make the change more frequent.
HTH
Old Apr 27, 2007 | 09:40 AM
92TypeR's Avatar
FSAE
Default Re: Iridium plugs: NGK or Denso ?? (Dave_B)
For anyone who considers themselves to be mechanically inclined enough to change their own oil, the only option should be the NGK BKR7E
NGK Coppers are the best plug you can run in your B-series.
For example, by simply changing the spark plugs on a moderately built B16 last week, we saw 12whp/9tq going from barely used (~5k mile) NGK Iridiums to BKR7E's.
The first thing we do when tuning a B-series is change the plugs to NGK coppers.
Old Apr 27, 2007 | 12:19 PM
Todd00's Avatar
I said I don't want a title!
Default Re: Iridium plugs: NGK or Denso ?? (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">For anyone who considers themselves to be mechanically inclined enough to change their own oil, the only option should be the NGK BKR7E
The first thing we do when tuning a B-series is change the plugs to NGK coppers.</TD></TR></TABLE>
12whp out of just changing plugs--and on a B16? I could see maybe 2-3, but to get 12whp something must have been wrong with the tune and/or plugs.
Iridium is not *that* bad of a conductor.
Smokey5176
May 8, 2007 05:01 PM
wreckedmyteg
Jan 25, 2005 02:03 PM
gsrguy
Jan 23, 2004 07:04 AM
unFOB4U
Aug 8, 2001 08:38 AM
Babalouie
Jun 24, 2001 07:33 PM
