Uninstalling OEM Mirriors
How do I go about uninstalling my Non Powered OEM Honda Mirriors on my 99 Civic Hatchback? My door panels are already off, as I removed my OEM Honda Side Molding not to long ago to make way for my JDM Honda Thin Side Molding.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2NR »</TD></TR><TR><TD CLASS="quote">Does the black plastic piece around the adjuster **** just pop off?</TD></TR></TABLE>
yeap.
yeap.
not sure on your car but on 92 - 95 civics it is very easy...
Pull the lil cover off from the inside...
8 or 10 mm forgot...
there is 3 nuts the need to be removed
pull thru
pull thru
very easy to remove the side molding just like eeveryoen said
pop the black tray off, i bleive its 3 8mm bolts and one 10mm bolt..i removed mine yesterday and i lost a screw =*(
WickedKP
Aug 2, 2007 07:18 PM
