E-Brake button...
My e-brake button is peeling and looks a bit crappy. Anybody replace this with something a bit nicer? Where can I get a new one? Can I get just the button from the dealer?
I think you should replace it with an aftermarket button that allows you to disable the ratchet function. I saw a link to the button posted on here about a year ago. When you turn the button to "disable," the e-brake doesn't ratchet, so you can use the e-brake like a ralley car without having to keep your finger on the button to keep the e-brake from locking in the engaged position. It's kind of silly, but it looks fun.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux »</TD></TR><TR><TD CLASS="quote">My e-brake button is peeling and looks a bit crappy. Anybody replace this with something a bit nicer? Where can I get a new one? Can I get just the button from the dealer?</TD></TR></TABLE>
mines pealing to damnit ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Batoutahell »</TD></TR><TR><TD CLASS="quote">I think you should replace it with an aftermarket button that allows you to disable the ratchet function. I saw a link to the button posted on here about a year ago. When you turn the button to "disable," the e-brake doesn't ratchet, so you can use the e-brake like a ralley car without having to keep your finger on the button to keep the e-brake from locking in the engaged position. It's kind of silly, but it looks fun.</TD></TR></TABLE>
that sounds pretty cool.
Flux - go ahead and grasp the rubber handle firmly while twisting it side to side...it will pull off leaving the button exposed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDC2 »</TD></TR><TR><TD CLASS="quote">isn't there a way you can just peel off the chrome?</TD></TR></TABLE>
What's underneath is ugly...
So, anubody know where to get an e-brake button?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stRtypR25 »</TD></TR><TR><TD CLASS="quote">i got mine from "evactox" i think that is how you spell it</TD></TR></TABLE>
No luck with a search on that name?
if you depress the stock button and drill a very small hole through the handle and the button you can stick a cotter pin through it and get the same effect. you wont be able to do that on the fly though.
Damn I might have to look into that. I make rally style u-turns at least 2 times a day and that e-brake ratchet is a bitch some times.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny »</TD></TR><TR><TD CLASS="quote">
Damn I might have to look into that. I make rally style u-turns at least 2 times a day and that e-brake ratchet is a bitch some times.</TD></TR></TABLE>
you do too?
you do too?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister »</TD></TR><TR><TD CLASS="quote">
you do too?
Who doesn't?
It can be useful to make a u-turn on a 10' turning radius.
you do too?
</TD></TR></TABLE>Who doesn't?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tko21 »</TD></TR><TR><TD CLASS="quote">does spoon sports make e-brake handles?
no.
How do you install one of those cusco ones?
no.
