Overheating problems
Old Sep 11, 2001 | 06:18 PM
wickedxbo1's Avatar
New User
Default Overheating problems
I just got my rex back not too long ago. I just dropped in a 93 gsr motor into my 89 rex. My watertemp gauge reaches to the top once in awhile when im at the stop light and goes back down after i start driving again. When im driving on the freeway or highway its fine, but when im in traffic in the hot heat, the motor gets very hot. Does anyone know what could be the problem? Should i get a bigger fan?
Old Sep 11, 2001 | 07:23 PM
ZColeon's Avatar
New User
Default Re: Overheating problems (wickedxbo1)
I know exactly- There is a sending unit on your head that is right below the distrubitor, about the with of a dime. 10mm I think. That sensor tells your fans to kick on/off pending the temp of the water in your head/motor. Also to solve your problem instantly you should be able to turn on your AC and your fans kick on any way instantly cooling the h20, between your ac and thermostat you should be cool. Other than that to help the issue get a lower deg. thermostat.
Old Sep 11, 2001 | 07:56 PM
wickedxbo1's Avatar
New User
Default Re: Overheating problems (ZColeon)
will i dont have a ac fan. can i just replace the sensor and it should be fine? how much do those sensors run for?
Old Sep 11, 2001 | 08:03 PM
wickedxbo1's Avatar
New User
does anyone have a pic of what the sensor looks like? if i change it out, then it should be fine right? the fans not kicking in when its suppose to, so i think that is that prob
Old Sep 12, 2001 | 08:36 AM
crx(gator)'s Avatar
this happened to my friend and he made a switch to turn on the fan fron inside the car...
Old Sep 12, 2001 | 08:49 PM
wickedxbo1's Avatar
New User
Default Re: Overheating problems (crxgator)
can you ask your friend how he did it?
91b18a1ls
Jul 18, 2022 11:15 AM
02K20A2Ep3
Jul 3, 2010 12:18 AM
JDM_rolex
Sep 2, 2009 11:04 AM
Dj^BaNNeD
Aug 20, 2007 01:37 AM
