WTB: '88-'91 CRX body panels, etc.
Looking for the rear fenders/quarter panels from an '88-'91 CRX as well as the passenger side door moulding. Rust-free and preferably black.
I'm also in need of a passenger side axle.
Please E-mail me @ LegendLS95@aol.com
Preferably Honda-Tech members with over 100 posts or those with references...
Thanks very much!
[Modified by LegendLS95, 9:31 PM 9/11/2001]
Thanks very much!
You do understand that the CRX is a unibody and the rear quarter panels are PART of the car right? You would have to have someone cut the quarter panels off of a car with a torch and weld them in place on your car...
Dustin
Dustin
Ugh. I went to get an estimate for the rust (rear panels) and I was told that unless I could get the rear panels, the body shop would have to get them from a dealer for obviously inflated prices. What should I do? - Thanks for the reply.
- Jim
- Jim
Hmm, I say look around for a CRX shell (no motor suspension or interior) and buy that. Heck, you could even swap everything in your car into it!
Or you could cut it up.
Dustin
Or you could cut it up.Dustin
Try a salvage yard and cut the parts you need. or try and repair it with aluminum and use fiberglass and construch a wide body.... The options are countless. Need to talk to a professional body shop or someone who knows how to work bondo or fiberglass
Thanks guys. I've actually talked to a friend of mine who has some exp. in bodywork. We're going to repair the rear quarters on a weekend with some bondo and aluminum sheets. After that, I'm going to have a local shop do the rust on the lower door panel.
LankorDie
Mar 9, 2018 03:12 PM
WH0R3nEF9
Jun 24, 2006 05:55 PM
