Hondata Intake Manifold Gasket???
Old Nov 16, 2003 | 07:12 PM
b16vtecsol's Avatar
Default Hondata Intake Manifold Gasket???
Yo guys,
Just wondering about this. I here that hondata makes some sort of plastic intake manifold gasket and that because of the material that it's made of and the thickness it gives you close to 6 (give or take) whp. I'm told it's because it keeps the heat from the head of the motor from heating the intake manifold. is this true or is it a bunch of b.s.? i could be wrong on some aspects of this, most likly the hp #.
B
Old Nov 16, 2003 | 07:24 PM
blackeg's Avatar
Default Re: Hondata Intake Manifold Gasket??? (b16vtecsol)
no bs- its true. the gasket helps keep the intake manifold cooler by reducing heat transfer between the head and mani. its something like 20 or so degrees cooler that its supposed to make the mani, resulting in like 5 percent hp gain. i have one, i dont know exaclty how much horse it added cause i had it installed with a bunch of other mods, but it does keep the mani a little cooler.
Old Nov 16, 2003 | 07:31 PM
3rdGteg's Avatar
Default Re: Hondata Intake Manifold Gasket??? (blackeg)
Aren't they reusable also unlike the stock ones? Btw, anyone know where to get the best price on one of these??
Old Nov 16, 2003 | 07:56 PM
SLeePeR012's Avatar
Default Re: Hondata Intake Manifold Gasket??? (3rdGteg)
Where can I get one?
How much can I expect to pay?
Old Nov 16, 2003 | 08:16 PM
b16vtecsol's Avatar
Default Re: Hondata Intake Manifold Gasket??? (SLeePeR012)
hondata says they are $60
Old Nov 16, 2003 | 08:27 PM
BolivianDc2's Avatar
http://www.an-r.com same thing as hondata but cheaper.
Old Nov 16, 2003 | 08:42 PM
IN VTEC's Avatar
Default Re: Hondata Intake Manifold Gasket??? (Bolivianstrtwpn)
The AN-R race gaskets fit better than the Hondata Race gaskets, so you won't need to modify them (as much - I found a port shoulder section that needed a little grinding). I don't know about the street stuff tho. I've never used those.
Old Nov 17, 2003 | 01:35 PM
Hondata's Avatar
The ANR gasket, according to their website, is not made out of the same material as Hondata's gasket.
Their R & D department seems to have copied verbatim text from Hondata's website to describe their product. In my mind this would cast some doubt on their R&D, if indeed there was any. But, as they say; imitation is the sincerest form of flattery.
We have not had any reported fitment problems with any of our street gaskets. The misalignment in the race gasket was fixed some time ago.
You can read the original information here.
http://www.hondata.com/heatshield.htm
Modified by Hondata at 4:21 PM 11/17/2003
Old Nov 17, 2003 | 01:51 PM
ce's Avatar
ce
I had no fitment issues with my Hondata gasket..A couple of hp gain,but not much..Best thing is that it's reusable..I like it
Old Nov 17, 2003 | 03:19 PM
TwoRedEGgs's Avatar
Default Re: Hondata Intake Manifold Gasket??? (ce)
Just put one on a GSR, no problems ! wont be able to tell the HP#'s due to a few more parts being added at the same time !
But I have seen ppl get some pretty decent #'s from just this mod, it basicly gets rid of the heat soak since the material is able to disapate heat!
Old Nov 17, 2003 | 04:52 PM
SLeePeR012's Avatar
Default Re: Hondata Intake Manifold Gasket??? (TwoRedEGgs)
Can some elabarate on the cuttin of some part?
It's showed here.
Old Nov 17, 2003 | 05:04 PM
dkim48's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLeePeR012 &raquo;</TD></TR><TR><TD CLASS="quote">Can some elabarate on the cuttin of some part?
It's showed here.
I believe that gasket is the race type which blocks off the coolant going to the manifold. the street type is already cut out. hth
Old Nov 17, 2003 | 06:05 PM
SLeePeR012's Avatar
Default Re: Hondata Intake Manifold Gasket??? (dkim48)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkim48 &raquo;</TD></TR><TR><TD CLASS="quote">
I believe that gasket is the race type which blocks off the coolant going to the manifold. the street type is already cut out. hth </TD></TR></TABLE>
Supurb(sp?)!!!
Old Nov 30, 2003 | 02:11 PM
3rdGteg's Avatar
Any best deals on these gaskets who've got them in stock for a b16a?
Old Dec 13, 2003 | 10:59 PM
SLeePeR012's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3rdGteg &raquo;</TD></TR><TR><TD CLASS="quote">Any best deals on these gaskets who've got them in stock for a b16a?</TD></TR></TABLE>
^What he said.
Old Dec 14, 2003 | 12:14 AM
enginetiks's Avatar
I've been using the same hondata gasket for over 2 years...I picked up 5whp, but that was with deleting the coolant lines running through the tb. We got tons of them in stock, but we sell them for the same price as hondata. If you find a good price give us a call, we might be able to price match.
modacar.com
Old Dec 14, 2003 | 01:16 AM
T.J.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLeePeR012 &raquo;</TD></TR><TR><TD CLASS="quote">Where can I get one?
How much can I expect to pay?</TD></TR></TABLE>
You can get them through Hondata , but if your serious about getting one you should also look in to the company Nextgear they make one just like it but supposedly better they it cools 40% more than Hondata. Heres a thread on it
https://honda-tech.com/zerothread?id=624233
Old Dec 14, 2003 | 01:23 AM
T.J.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3rdGteg &raquo;</TD></TR><TR><TD CLASS="quote">Aren't they reusable also unlike the stock ones? Btw, anyone know where to get the best price on one of these??</TD></TR></TABLE>
yes they are reusable
Old Dec 14, 2003 | 03:33 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: Hondata Intake Manifold Gasket??? (Skunk2whore)
Ill bump for the Nextgear
Either one you get, it will be a good buy. But the Nextgear is a great product made!
Old Dec 14, 2003 | 08:38 AM
BERT-O's Avatar
Default Re: Hondata Intake Manifold Gasket??? (mschvs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mschvs &raquo;</TD></TR><TR><TD CLASS="quote">I've been using the same hondata gasket for over 2 years...I picked up 5whp, but that was with deleting the coolant lines running through the tb. We got tons of them in stock, but we sell them for the same price as hondata. If you find a good price give us a call, we might be able to price match.
modacar.com</TD></TR></TABLE>
Can you just do that with a OEM gasket. I've never ran the coolant lines/hose through the T/B and IACV.
Old Dec 14, 2003 | 09:09 AM
snowseeker's Avatar
Default Re: Hondata Intake Manifold Gasket??? (BERT-O)
Ok, this sounds far fetched and not real, but hear me out. This last summer I was at a RSD (real street drags) at a track. There was a guy there that I knew threw the net. A bunch of my friends know him for awhile. We were standing around talking to him by his car (8.xx sec. chevy 2). When there wasn't alot of people around he said "you know why I am so fast" I said why? He said (as he pointed to his carb spacer) "because of that" I was like ok... He said that carb spacer is one of four in the US. I was still like ok... He said that carb spacer is a tile off of the Spaceshuttle. (you know the heat tiles on the front of the shuttle) He said when the temp outside is under 55 F when the car runs the carb frosts up. (Now that is cold!) After he made a pass on the track I went over and felt the carb on his car. It was cool, just like when you go out to your car in the morning and feel the motor.
So anyhow. Ever since that day I have been keeping my ears open for one of these tiles.
Anyone know what the tiles are made of? Or have one in there basement? LOL
Old Dec 14, 2003 | 09:15 AM
SLeePeR012's Avatar
Default Re: Hondata Intake Manifold Gasket??? (snowseeker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">Ok, this sounds far fetched and not real, but hear me out. This last summer I was at a RSD (real street drags) at a track. There was a guy there that I knew threw the net. A bunch of my friends know him for awhile. We were standing around talking to him by his car (8.xx sec. chevy 2). When there wasn't alot of people around he said "you know why I am so fast" I said why? He said (as he pointed to his carb spacer) "because of that" I was like ok... He said that carb spacer is one of four in the US. I was still like ok... He said that carb spacer is a tile off of the Spaceshuttle. (you know the heat tiles on the front of the shuttle) He said when the temp outside is under 55 F when the car runs the carb frosts up. (Now that is cold!) After he made a pass on the track I went over and felt the carb on his car. It was cool, just like when you go out to your car in the morning and feel the motor.
Anyone know what the tiles are made of? Or have one in there basement? LOL</TD></TR></TABLE>
Like, woah
Ive yet to attend RSD.
You should come down to Route 66
Old Dec 14, 2003 | 09:32 AM
TEAMGENDAI's Avatar
Hondata gasket definetly works talking from expirence with it.
Old Dec 14, 2003 | 06:29 PM
denny's's Avatar
bumpers
Old Dec 14, 2003 | 08:39 PM
snowseeker's Avatar
Like, woah
You should come down to Route 66 </TD></TR></TABLE>
Thats a long drive for me. I live in central WI
