92 integra b20/vtec, need suggestions on motor mounts.
My stock tranny mount has gone bad. Looking to change all my mounts while im at it. Any suggestion on what mount to get that can handle the motor and my ACT 6 puck clutch.I definatly want something bolt on, no fab work. Tried searching the net but most mounts are made for g3 intgras. Help me out.
Simply put no. The mounts are different. The thrid gen Integra has 5 mounts. Two passenger side mounts, one rear mount, and two driver side mounts. The second gen Integra has one passenger side mount, one rear mount, one driver mount, and one front mount. If you are looking for new OEM ones I would suggest http://www.acuraautomotiveparts.org If you are in search of a more solid mount you have two options that I am aware of, either using energy suspension mount inserts these will give you alot of internal vibration, or there is this material that comes in a caulking tube that you can apply to the open spots of your motor mounts. The stuff in the tube is made by 3M its called windo weld, I beleive. But this is just like adding inserts.
Josh
Josh
im using the stock mounts with energy suspension Polyurehtane mount inserts and they work fine, you can find some at inlinefour.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gen2B16 »</TD></TR><TR><TD CLASS="quote">im using the stock mounts with energy suspension Polyurehtane mount inserts and they work fine</TD></TR></TABLE>
We used those in a customer's 92 Integra with a built LS/VTEC (CTR pistons, CTR cams, etc, etc, etc) and used the ES inserts and the motor was very solid in there and wouldn't move. Granted theres more vibration but you've got to give a little to get a little.
JaguarS4R
Honda Civic (2001 - 2005)
Feb 20, 2010 06:00 AM
