What could cause bad gas mileage?
Old Nov 16, 2003 | 06:35 PM
Sassafrass's Avatar
Default What could cause bad gas mileage?
I have always gotten bad gas mileage from day 1 with my car, on my stock DX motor got about 200-250KM's to a full tank, I got my LS and that didnt change, now all of a sudden I filled up on gas I've drvin the car maybe 20-40km's and I'm down to half full. I'm think a leak somewhere? And since my swap I have not changed plugs or anything like that.
Old Nov 16, 2003 | 06:44 PM
Spade's Avatar
Default Re: What could cause bad gas mileage? (Sassafrass)
Clogged air filter
Clogged injectors
bad O2 sensors
bad spark plugs
bad spark plug wires
bad distributor cap
poor ingnition timing
aggressive driving
Old Nov 16, 2003 | 07:04 PM
99blackcivicSi's Avatar
Default Re: What could cause bad gas mileage? (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade &raquo;</TD></TR><TR><TD CLASS="quote">
aggressive driving
Old Nov 16, 2003 | 07:11 PM
MrIllegalX's Avatar
Default Re: What could cause bad gas mileage? (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">
lol. i drive aggressive everywhere and I'll still get 250-300 miles a tank.
Old Nov 16, 2003 | 07:27 PM
Sassafrass's Avatar
Default Re: What could cause bad gas mileage? (MrIllegalX)
On this tank I dint drive hard at all, I was only driving to school and work, plus its very slick out on the roads, so even if I wanted to I can't get any traction.
Old Nov 16, 2003 | 07:32 PM
Ricey McRicerton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrIllegalX &raquo;</TD></TR><TR><TD CLASS="quote">
lol. i drive aggressive everywhere and I'll still get 250-300 miles a tank. </TD></TR></TABLE>
Hell, I boost everywhere and can still get 330 or 340 a tank.
Old Nov 16, 2003 | 07:35 PM
righteyeblind's Avatar
Default Re: What could cause bad gas mileage? (Ricey McRicerton)
Try seeing if the fuel level sensor is out...Maybe you are still getting the same mileage but your sending unit isnt reading the fuel level correctly
Old Nov 16, 2003 | 07:44 PM
shermanyang's Avatar
Default Re: What could cause bad gas mileage? (righteyeblind)
do you smell fuel anywhere at all? maybe you have a fuel leak somewhere. what's your fuel pressure set at? upgraded ecu?
when i had a stock LS in my 94 SI, i was able to drive from st.paul all the way past Madison, WI on one tank of gas. about 4+hours of driving.
civicmon's Avatar
honestly, you can't burn gas THAT fast... the exhaust would be pitch black, so if you are, check the exhaust.
I'd bet it's the sensor or the fuel gague itself perhaps.
Old Nov 16, 2003 | 08:04 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (civicmon)
if your car was getting 40mpg to a half tank , i dont think the car would run off that much gas , has to be a leak
Old Nov 16, 2003 | 08:17 PM
Sassafrass's Avatar
Default Re: (Hella_JDM)
ont smell any gas, nor is there any on the ground.
Stock ECU, stock fuel pressure. everyhting is stock right now, except i/e
Old Nov 16, 2003 | 08:18 PM
KayOs's Avatar
tire pressure is a big factor when determining gas mileage.
Check your tires and see what psi you are running.
Old Nov 16, 2003 | 09:36 PM
Default Re: (Sassafrass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sassafrass &raquo;</TD></TR><TR><TD CLASS="quote">ont smell any gas, nor is there any on the ground.
Stock ECU, stock fuel pressure. everyhting is stock right now, except i/e</TD></TR></TABLE>
you won't be able to see any gas on the ground if it's leaking. it evaporates almost instantly if in small quantities.
it's odd that you would lose so much gas...do you have any CELs? check to see if your CEL bulb is working. maybe you've got a bad O2 or something and running in limp mode? sorry for the guesses but just trying to help.
Jarred b18
61
Dec 31, 2006 10:51 AM
NerveAgent
Sep 28, 2005 08:23 PM
92LUDA23
May 11, 2005 12:00 PM
Ronnie00si
11
Mar 29, 2004 12:36 PM
Yyz
Jun 13, 2003 01:56 PM
