b-series transmission internals question: 'small spline' to 'big spline' differences?
Old Nov 16, 2003 | 06:21 PM
acy76's Avatar
Default b-series transmission internals question: 'small spline' to 'big spline' differences?
Thought I read about this somewhere in another post, but I'll be damned if I can find it. Wondering if anyone knows what changed in the b-series trans between 91 and 92+ -- is the newer design stronger? thought I also heard something about there being dual synchros on 2nd gear or something in the newer design? maybe on the GSR model only? this is assuming that all the 92+ b-series internals are the same, as i have read in a few posts (cable vs. hydraulic clutch differences aside). thanks for any info.
Old Nov 16, 2003 | 07:57 PM
rsbad454's Avatar
Default Re: b-series transmission internals question: 'small spline' to 'big spline' differences? (acy76)
88-91 smaller diamter input shaft while 92+ have bigger diameter input shaft.....as far as strenght im not sure.
Old Nov 16, 2003 | 08:06 PM
mmuller's Avatar
Mad Scientist
Default Re: b-series transmission internals question: 'small spline' to 'big spline' differences? (rsbad454)
also the R and s80-y80 gsr tranny's have tampered roller bearings.while the others have ball bearings
Old Nov 16, 2003 | 08:15 PM
PhatOptimo's Avatar
In 92+ trannys the differential pin is hardened from the factory. Pre 92 B and d deries tranny they are not. If this pin shears (common on the pre 92 trannys) you can say bye bye to your differential and tranny case. I don't know about the syncros. I do know the new s2000 has carbon fiber syncros. Bad *** sheot!
Old Nov 16, 2003 | 08:16 PM
acy76's Avatar
Default Re: b-series transmission internals question: 'small spline' to 'big spline' differences? (mmuller)
Just got hold of a Helm's for the 2nd gen integras - the gsr transmission does have double-cone synchros on second gear (i believe).. but the LS trans does not. guess that settles that. any word on strength differences between the two? [I am building an engine for my 91 integra, and would like to replace my aging trans while i'm at it. if the 92-93 is a better unit, i'll go with it instead of another 91.]
Old Nov 16, 2003 | 08:17 PM
PhatOptimo's Avatar
BTW the diff pin would only be an issue if the tranny is NON LSD.
looseOFFboost
Transmission & Drivetrain
Aug 16, 2009 01:45 PM
christion
Feb 4, 2008 03:17 PM
ED9man
Dec 18, 2005 08:43 PM
