ex auto harness in a man swap car???
Old Nov 16, 2003 | 06:12 PM
b20vtecEK's Avatar
Default ex auto harness in a man swap car???
Ok im droppin a b20vtec into my coupe(ek96) and Im getting a ex harness instead of my dx one to make **** go smooter. Now my question is, can I just use a automatic harness and leave the connectors I dont need unpluged and since my ecu is man the connections dont exist and therefore wont throw a CEL or will this just not work at all?
Old Nov 17, 2003 | 06:12 AM
b20vtecEK's Avatar
Default Re: ex auto harness in a man swap car??? (jayden)
any info??
Old Nov 17, 2003 | 06:45 AM
leadtrum's Avatar
you could but you'll just end up with unused plugs taht will confuse you...plus you'll need to splice more connections from the b series harness....just get a manual one and save some trouble
Old May 3, 2004 | 10:45 PM
JDMH22HATCH's Avatar
Default Re: ex auto harness in a man swap car??? (leadtrum)
Just bringin this back cause I'm kinda curious myself. I have 5 engine harnesses lying around and some are auto and the others manual. Besides have leftover plugs, is the wiring to the dizzy and everything the same? Any pinouts I have to change? This is just for the engine harness, I am still retaining my factory chassis harness
Old May 3, 2004 | 10:58 PM
poison's Avatar
Default Re: ex auto harness in a man swap car??? (b20vtecEK)
The auto harness will work. Yes the pinouts are the same, the only thing is auto harnesses have a lil bit of extra wiring which a manual ECU will not look for.
Any pinout the manual ECU doesn't look for that the auto harness has for a wire will be dead -- so you can burn it, leave it there, or use it for nawss.
Get the point?
Old May 3, 2004 | 11:12 PM
Default Re: ex auto harness in a man swap car??? (poison)
LOL, thanks Brando, wish you were here to see the beast finally fire up for the first time
eebaker
Nov 19, 2017 04:47 AM
EKCivicGirl
Mar 21, 2011 06:58 PM
badb16rex
May 2, 2007 12:16 PM
turboed4life
Dec 13, 2004 04:20 PM
NatedoggAZ
13
Nov 26, 2003 10:20 PM
