fs: Tein Type RS for EG
Type RS damper has the advantage over the RA and RE with its damping force adjustment feature.
With separate compression and rebound adjustment (16 levels X 16 levels), this allows the driver to set up the suspension damping force to meet any track conditions.
Furthermore, wishbone suspension and multi-link suspension have a reserve oil tank for larger oil capacity.
Strut type dampers are designed with inverted shocks for more horizontal stability.
* Mono-tube design for maximum performance.
* Compression and rebound damping force is adjustable separately (16 levels X 16 levels).
* Extra reserve oil tank for larger oil capacity for wishbone and multi-link suspension.
* Inverted structure for more horizontal stability for strut type suspension.
* Exclusively designed pillow ball upper mounts for optimize performance.
* Available for overhaul.
Includes Tein Springs, and two sets of Eibach Race Springs ($500 value). I will throw in the JDM LCA`s, too. Only have 3k miles on them.
$1600
Ryan
Modified by vtecvoodoo at 8:42 PM 12/17/2003
Also have a set of kg/mm 16-way adjustable coilovers for sale. Only set in the USA I believe. Come standard w/ pillowball mounts.
$1200
$1200
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReaL JDM Eg6 »</TD></TR><TR><TD CLASS="quote">bump for some good ****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo »</TD></TR><TR><TD CLASS="quote">Also have a set of kg/mm 16-way adjustable coilovers for sale. Only set in the USA I believe. Come standard w/ pillowball mounts.
$1200</TD></TR></TABLE>
any chance you have pics of these lying around?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .jefs0ng »</TD></TR><TR><TD CLASS="quote">All I need is an EG for these coils! hahaha.. very sexy spicy stuff.</TD></TR></TABLE>
Bad *** damper kit. I'd pick these up right now if I didn't already have a set. These things will blow anything else out of the water that Tein or any other JDM company makes while still being streetable.
