review of action 1ks
Old Nov 16, 2003 | 04:27 PM
91integraLSVTEC's Avatar
Default review of action 1ks
i purchased the action 1ks from ksmotorsports, i dont know why people raving about there customer service it wasnt that great.. anywayz just my luck the clutch kit i got was correct for my car except for the clutch disk itself so i had to waste an extra $20 for nextday air shipping to action clutch in ca.. guess it was packed wrong just my bad luck i ended up with that..
first impressions:
wow! i couldnt belive how much lighter the pedal felt! well after using a cm stage4 for 11 months i guess any clutch would of felt lighter lol but i was suprised how well it grabed.. it actually took some time getting used to it, i was stalling my car at almost every light during the first couple days lol although it was performing well on the street i wanted to see what it was really made of at the track.. i gave it a 800 mile break in period before i head out..
performance at the track:
as we all know kevlar disc is not good for drag racing.. but i figured since i would have to wait 45min- 1hr for a run that would give it enough time for the disc to cool.
my first run with it i was suprised how well it held the power! shifting gears at 8700 rpms was much easier than before and was now able to ride the clutch at pull off instead of on and off stage 4. it was holding up fine until after the 3rd run when it started to slip in 4th =o( i called it a night and returned the next weekend.. no problems until the 5th run.. guess it cant take back to back runs but it performs great after 30 minz of cooling in 70degree weather.
conclusion:
this clutch is great if your planning on having a car with just bolt ons.. excellent clutch for an autoxer. maybe i should of went with the 2ks because ive never heard of a cm stage 3 slip on them at the track, it might of lasted a bit longer.. i chose this clutch cause i liked the feeling of not worrying about clutch wear and taken alot of abuse =op i also like autoxing more than drag.. i'm happy with the 1ks, its perfomance is great and belongs on a track car, not a drag car =o)
Old Nov 16, 2003 | 04:34 PM
Default Re: review of action 1ks (91integraLSVTEC)
here some pics
before resurfaced cm 7.5 fw
after
action 1ks
action pressure plate
Old Nov 16, 2003 | 04:44 PM
H22A EG6's Avatar
looks dis manny times
Old Nov 16, 2003 | 04:48 PM
Agent#ONE's Avatar
Default Re: review of action 1ks (H22A EG6)
let us know in 500 miles
Old Nov 16, 2003 | 05:16 PM
gsxr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91integraLSVTEC &raquo;</TD></TR><TR><TD CLASS="quote">i purchased the action 1ks from ksmotorsports, i dont know why people raving about there customer service it wasnt that great..
I agree, I got sent a wrong pp and an oversized adjustment tool for the disc.
Old Nov 16, 2003 | 05:40 PM
BolivianDc2's Avatar
Default Re: review of action 1ks (gsxr)
I have the stage 2 KS right now, been using it for about 15,000 miles and it holds up great to just bolt ons. What LB pressure plate do you ahve?
Old Nov 17, 2003 | 07:42 PM
Default Re: review of action 1ks (Bolivianstrtwpn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bolivianstrtwpn &raquo;</TD></TR><TR><TD CLASS="quote">I have the stage 2 KS right now, been using it for about 15,000 miles and it holds up great to just bolt ons. What LB pressure plate do you ahve?</TD></TR></TABLE>
i dont know the lb pressure plate but its a single diaphram.. you have the dual, i guess that would make your pedal stiffer.. makes me wonder if the 2ks would of held up better
Old Nov 17, 2003 | 08:22 PM
Project SSAP1's Avatar
do u have any chatter issues with the 2KS??? and how is it for street driving??
this is my clutch of choice!!! but i dont know if i should go for the 1ks or the 2ks...hey how much did u pay for the 1ks?? and what is the price difference of the 2ks???
Old May 22, 2005 | 02:01 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: review of action 1ks (Project SSAP1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project SSAP1 &raquo;</TD></TR><TR><TD CLASS="quote">
this is my clutch of choice!!! but i dont know if i should go for the 1ks or the 2ks...hey how much did u pay for the 1ks?? and what is the price difference of the 2ks???</TD></TR></TABLE>
bump so a 2ks has a dual diaphragm? is that the only difference? How different is the pedal feel of a 2ks compare to an HDSS?
Old May 22, 2005 | 03:14 PM
Default Re: review of action 1ks (BrokeAssPinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy &raquo;</TD></TR><TR><TD CLASS="quote">
bump so a 2ks has a dual diaphragm? is that the only difference? How different is the pedal feel of a 2ks compare to an HDSS? </TD></TR></TABLE>
I've never driven a car with HDSS, but the 2ks is rated at 3000lbs dual diaphram.
I believe the 2ks could hold 300lbs of tq, the 1ks could hold 200lbs tq, the 1MD 250 lbs
I've had the 2ks clutch for over 2 years now, the only issues which have popped up is the clutch hose has gone bad (probably from the increased pressure, no biggie it was expected) and it sounds like the throw out bearing might be going out . Overall though the clutch is five stars and hase been through alot of drag days
Old May 22, 2005 | 03:21 PM
Default Re: review of action 1ks (BolivianDc2)
cool, I'll most likely get a 2ks when I prep by d16 for turbo,
Old May 22, 2005 | 04:38 PM
Alchemist's Avatar
The "2" series clutches are dual diaphragm, while the "1" series are single diaphragm. The "2" are about 100% firmer than stock and the "1" are 30% firmer than stock pedal pressure. If you guys have any questions about the Action Clutches then just let me know, and Ill try to answer them for you.
Old May 22, 2005 | 07:48 PM
iH8RICERZ's Avatar
Default Re: review of action 1ks (Alchemist)
how much do those clutches go for?
AllShowNoGo727
Feb 26, 2011 08:54 AM
LSVTEC 91 Civic
May 20, 2005 04:31 PM
gloryhog
Aug 23, 2003 03:17 PM
mattL
Jan 13, 2002 01:53 PM
