Crower Stage II H22 Cams Questions
Old Nov 16, 2003 | 02:34 PM
CD5 Sedan's Avatar
Default Crower Stage II H22 Cams Questions
on crower's page regarding the h22 cams: http://www.crower.com/cat/impo...shtml what's the difference between the Stage II Cams: 63422 & 63422A. can anyone provide any information providing all that is different betweent the 2? do the Stage II cams with the stock idle lobes still provide the same (15-18hp) as advertised on the page?
Old Nov 16, 2003 | 08:50 PM
machine4321's Avatar
yes they will produce the same power up high in the rpm
the stock lobes give you good drivability and good for emissions and what not....
imo the difference from stock lobes and then the stage 2 vtec cams is too far apart....the cams with the lager non vtec lobes will gain you power in the low rpm aswell .....somthing too think about when buildin gyour car...depends on what you want to sacrifice
aaaabbbb
Mar 25, 2005 01:03 PM
95accordh22a
Feb 10, 2005 03:28 AM
