B18c1 with JDM ITR pistons
Old Nov 16, 2003 | 12:46 PM
Thrashin's Avatar
Default B18c1 with JDM ITR pistons
will this change the compression #s from the stock gsr #s? i want my comression somewhere in the high 11 range and im wondering what i will need to do to get it there. heres what is going together:
gsr block
JDM ITR pistons
JDMITR rods
gsr head
3 angle valve job
type r valves
skunk2 ti retainers
skunk2 valve springs
skunk2 stage 2 cams
skunk2 intake mani.
spoon cam gears
the head has not been shaved, can anyone tell me what the compression will be with those pistons? if it does not effect the compression what headgasket would you recomend to get me in the 11.6 - 11.8 range?
i have a SGT tuned ecu (skunk copy) i will be running and im shooting for 205whp. any sugestions on anything are apreciated.
Old Nov 16, 2003 | 01:01 PM
ArinX's Avatar
Default Re: B18c1 with JDM ITR pistons (thrashin)
civic type r pistons would get u into about 12 compression
jdm type r pistons would get you about 11.3
according to the cspeed calulator that is
Old Nov 16, 2003 | 01:02 PM
Thrashin's Avatar
Default Re: B18c1 with JDM ITR pistons (ArinX)
thanks, so what head gasket could i use to bump me up another .5? id like to be right under the 12.0 mark.
Old Nov 16, 2003 | 01:51 PM
Mr Hammond's Avatar
a/k/a Jomo
No head gasket is going to bump you up that high. Get differnt pistons or mill the head.
Old Nov 16, 2003 | 01:53 PM
Thrashin's Avatar
Default Re: B18c1 with JDM ITR pistons (Mr Milano)
ok, so i should just ditch the itr pistons and go with the ctr's.
Old Nov 16, 2003 | 01:57 PM
Mr Hammond's Avatar
a/k/a Jomo
CTR's will put you at around 12.3:1. Depends on what cams, any head work, what you are using to tune etc...
For the compression you are wanting just do O/S JDM B16A pistons (P30).
Old Nov 16, 2003 | 02:00 PM
Thrashin's Avatar
i posted everything i have in the 1st post. so if i use the ctr pistons it will put me at around 12.3 ok, if im at 12.3 will i have any problems running on pump gas without constant tuning? we do get 93 octane here.
Old Nov 16, 2003 | 02:24 PM
Mr Hammond's Avatar
a/k/a Jomo
Yes you would need tuning. 12.3:1 can be done on 93 octane w/ stock timing.
tegra2G
11
Oct 26, 2008 04:37 AM
acura_b18c1
15
Jun 4, 2006 08:31 PM
ndlyng
Oct 10, 2005 01:59 PM
cjohnson_2
Aug 25, 2004 12:04 AM
