Hondata Intake Manifold Gasket: Who's got it?
Old Nov 16, 2003 | 11:15 AM
Civic Hx-T's Avatar
Default Hondata Intake Manifold Gasket: Who's got it?
If you have it, how's the motor running afterwards? SOHC owners especially post up.
Anything impressive? For sixty I think i'll try it out next month.
Old Nov 16, 2003 | 11:54 AM
euclid's Avatar
Default Re: Hondata Intake Manifold Gasket: Who's got it? (Ferio Rice)
i got it y0!!!
i installed it when i did my swap so i cant tell if it made a difference. i would say if any performance is noticed it is b/c the runners are lengthened a few mm, not really the change in temp.
it will be perfect for a set of itbs though.
Old Nov 16, 2003 | 12:25 PM
vtecdamian's Avatar
Default Re: Hondata Intake Manifold Gasket: Who's got it? (euclid)
i got one...no biggie...............after 30 mins the whole manifold is as hot as can be!
Old Nov 16, 2003 | 12:38 PM
GPoodle
Guest
Posts: n/a
I got one and I cant really say if it helped.
But when I installed mine I didnt scrape off all the old gasket and it cause a huge vaccume and coolant leak that caused to the motor to pulse-rev from 700-7000rpm!!!
So if you install it make sure you clean up the mannifold and block surfaces
Before after driving around I couldnt touch my intake pipe by the TB or the IM itself, now however with the hondata IM gasket its just luke warm after some hard driving.
... its doing its thing i guess!
Old Nov 16, 2003 | 03:23 PM
euclid's Avatar
Default Re: (GPoodle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GPoodle &raquo;</TD></TR><TR><TD CLASS="quote"> now however with the hondata IM gasket its just luke warm after some hard driving.
... its doing its thing i guess!</TD></TR></TABLE>
ive noticed the same.
Old Nov 16, 2003 | 07:18 PM
blackeg's Avatar
i 3rd this. as far as preformace increase, i cant tell exactly cause i had a head swapped and some other work done when it got installed.
M2S~Jaime
Dec 14, 2006 03:04 PM
whp
Oct 14, 2004 01:19 PM
ITSTOCK
Jan 12, 2004 02:46 PM
NA gs-R 05 C
May 23, 2003 05:58 PM
four27
Oct 25, 2002 05:16 AM
