Want to Buy Want to Trade/Want to Buy
WTB: Valve Adjustment Tool
Old Nov 16, 2003 | 11:04 AM
DB8_TEG's Avatar
Default WTB: Valve Adjustment Tool
I am looking for a valve adjustment tool to do it on my 94 LS. It can be a home made one or an actual one. I am in Canada so you must be willing to ship it to me. I was going to make one but I don't have a torch to heat the wrench up enough. TIA.
Old Nov 16, 2003 | 11:08 AM
JDMH22HATCH's Avatar
Default Re: WTB: Valve Adjustment Tool (DB8_TEG)
You don't need the valve adjustment tool on an LS. Just use a 10mm wrench, a flat head screw driver to adjust and wallah. But if you insist on having one, Snap-On has them for around $50
Old Nov 16, 2003 | 11:09 AM
chad's Avatar
Moderator
Default Re: WTB: Valve Adjustment Tool (JDMH22HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22HATCH &raquo;</TD></TR><TR><TD CLASS="quote">You don't need the valve adjustment tool on an LS. Just use a 10mm wrench, a flat head screw driver to adjust and wallah. But if you insist on having one, Snap-On has them for around $50</TD></TR></TABLE>
aren't ls's 12 mm? zc's are 12 mm.....either way just use an open end wrench and screwdriver and you'll be fine...
Old Nov 16, 2003 | 11:14 AM
DB8_TEG's Avatar
do I have to modify a 10 or 12 mm wrench at all to adjust it or can I just use it as it is? and I assume it's better for a two people to do it?
jordy478
Aug 7, 2012 08:47 PM
Gomdohree
Jun 2, 2008 05:53 PM
Powered by VTEC
16
Jan 20, 2008 03:47 PM
silver5spd
May 31, 2005 06:08 PM
pgflash
Oct 3, 2004 07:41 AM
