my engine died twice before I found out I was more than quart low on oil. What damage should I look
Old Nov 16, 2003 | 08:32 AM
Sinner's Avatar
Default my engine died twice before I found out I was more than quart low on oil. What damage should I look
It seems to be up and running find now, but I know I caused some damange. It died twice once, after hitting a bump and again after a hard pull.
Nick
Old Nov 16, 2003 | 08:38 AM
asianic415's Avatar
Default Re: my engine died twice before I found out I was more than quart low on oil. What damage should I
i was running bone dry before i realized that i had no fresh oil. i'd check the piston rings, they might be burnt out.
Old Nov 16, 2003 | 01:47 PM
btleier's Avatar
The only real way to tell for now is to rip apart your block? Are you getting knock? If it was bad it could have gone as far as to scoring your pistons as well.
Old Nov 17, 2003 | 11:41 AM
roadrunner's Avatar
I thought only cats get "da mange" -- j/k...
Low oil doesn't usually cause the engine to stall, unless it's seized, and you usually know when that happens...
turboteg90
Feb 11, 2008 08:07 PM
dc4g
Nov 22, 2005 06:27 AM
MikeSarr_GSR
Dec 6, 2004 09:03 PM
IloveNewt
Dec 21, 2003 10:18 AM
Cal_Ripcurl
Feb 19, 2002 12:36 PM
