If I got an Integra RS or GSR and had 5000 to spend on it what should I get
Old Nov 16, 2003 | 07:53 AM
Jay J's Avatar
Prince of Zamunda
Default If I got an Integra RS or GSR and had 5000 to spend on it what should I get
First of all what what would you get a GSR in worser condition, older, more miles, and worse paint or a newer, cleaner, less milaged, nice paint Integra RS. I don't actually care much about VTEC though it does supply a lot of power to these B engines. If I got an RS could I do a smog legal LS block or would it need to be under the table legal??.. How ever when I started to search for cars I found a few RS's with the B18C3 block(GSR?) or should I steer away from a car that's a undergoing project or a finished project which I know will save me $$$....
If I got an Integra RS what should I do for it with $5000ish, after the alarm
If I got an Integra GSR what should I do with the $5000 for it after shaving off the DOHC vtec emblem, switching Valve covers to the B18C1 one, and a really good alarm (Clifford or a Viper pager alarm) ?
Thanks
Old Nov 16, 2003 | 07:57 AM
Jay J's Avatar
Prince of Zamunda
Default Re: If I got an Integra RS or GSR and had 5000 to spend on it what should I get (neuspeed)
By the way does OBDI or OBDII matter I remember when I worked with lexus SC's the OBDII didn't respond well to modifications like the intake, ignition, and ECU threw codes out.... By the way years are 94-01 and if it comes to a certain block of years it'd need to be 94-95 or 98-01
Old Nov 16, 2003 | 08:02 AM
Jay J's Avatar
Prince of Zamunda
Also the GSR would take a bigger hit on my wallet with gas then again the integra isn't a gas guzzler (premium on GSR?)
Old Nov 16, 2003 | 08:04 AM
P1mpSlap's Avatar
Get the RS and put together a serious turbo kit and some forged internals.
Old Nov 16, 2003 | 08:05 AM
six_speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neuspeed &raquo;</TD></TR><TR><TD CLASS="quote">By the way does OBDI or OBDII matter I remember when I worked with lexus SC's the OBDII didn't respond well to modifications like the intake, ignition, and ECU threw codes out.... By the way years are 94-01 and if it comes to a certain block of years it'd need to be 94-95 or 98-01</TD></TR></TABLE>
type r=b18c5
gsr=b18c1
rs/ls/se/gs=b18b
obd1 would be the choice if one was to do major internal mods. ie cams/pistons etc.
94-95 obd1/96-99obd2a/00-01obd2b
well if you are buying an older gsr model or any used car you should do a compression check to see if the motor is healthy. Look around for wears..ie engine bay/axels/fluids leaking etc...what you normaly do when buying a used car.
btw it it were buying a car, i would pick one with vtec. It's a good base to start working with.
Old Nov 16, 2003 | 08:11 AM
Jay J's Avatar
Prince of Zamunda
Default Re: (P1mpSlap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">Get the RS and put together a serious turbo kit and some forged internals. </TD></TR></TABLE>
Not a bad idea but when it comes to forged internals all I'd do without going total over board would be new Valves, cams, cam gears, and springs .. The RS has no power door locks?? That's all I really want when it comes to power or assisted crap in the car....
Old Nov 16, 2003 | 08:15 AM
P1mpSlap's Avatar
well if we are going to talk all motor....
<u>Top End</u>
Header Tech Header or SMSP
SKunk2 Stage 3 Cams
Skunk2 Ti Retainers
Skunk2 Ti Valvetrain
Ferrera Valves
TWM ITB setup or Toda Sports Injection Kit
<u>Bottom End</u>
CTR Pistons / or CP Pistons (12-12.5:1 CR)
Cunningham Rods
Micropolished, knifed, and balanced crank
ACT Xtreeme Pressure Plate
ACT Street Disc
Comptech 6.7lb flyhweel
+machine work/head work
That's just to name a few and would no doubt lay down a good 200+ whp and is well under 5K dollars.
This is pretty much the setup I'm going to run this winter.
Old Nov 16, 2003 | 08:20 AM
Quiks66's Avatar
Default Re: (neuspeed)
I'm stumped...have you ever worked with Hondas/Acuras before? Nearly everything you want to know about an LS motor vs. a GSR motor can be found if you search. Not trying to flame here, but this looks like a worthless post...?
Old Nov 16, 2003 | 08:21 AM
Jay J's Avatar
Prince of Zamunda
Some one lend me 7000 now... Please I want to go get my car Wasn't this on sale a year ago on Ebay?
1998 ACURA INTEGRA, DOHC VTEC, right hand drive, too much to list, featured in SS magazine 12/ 02, regist & inspected, must see to apprec, none cleaner, email for detailed pictures and disc, must sell, $7,000 obo
Old Nov 16, 2003 | 08:26 AM
P1mpSlap's Avatar
It's a Jay Smith copy.
Old Nov 16, 2003 | 08:55 AM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">It's a Jay Smith copy.
$7,000 for a 98....how many miles??? That looks like a good deal to me
Old Nov 16, 2003 | 09:00 AM
integranator's Avatar
Default Re: (arizsun21)
turdbo it w/ that extra 5g's!!!!
Old Nov 16, 2003 | 09:07 AM
XtremeCarTuner's Avatar
huh.. Coulda sworn that it was really his car.
Old Nov 16, 2003 | 12:05 PM
lustedp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neuspeed &raquo;</TD></TR><TR><TD CLASS="quote">Some one lend me 7000 now... Please I want to go get my car </TD></TR></TABLE>
I thought you said you wanted an integra, this is clearly an accord
Old Nov 16, 2003 | 03:02 PM
:jdmshmaydm:'s Avatar
Default Re: (lustedp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lustedp &raquo;</TD></TR><TR><TD CLASS="quote">
I thought you said you wanted an integra, this is clearly an accord </TD></TR></TABLE>
haha.
Buy 5000 jumbo jacks.
Old Nov 16, 2003 | 03:05 PM
P1mpSlap's Avatar
Default Re: (XtremeCarTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XtremeCarTuner &raquo;</TD></TR><TR><TD CLASS="quote">
huh.. Coulda sworn that it was really his car. </TD></TR></TABLE>
nah tons of people have ripped his design. Not to mention he sports red GAB wheels.
b18c4door
Dec 28, 2009 08:35 AM
Kentagious
Mar 6, 2006 10:23 AM
bg-33p
Audio / Security / Video
May 24, 2005 06:29 PM
Brian-Brian
Jan 27, 2003 10:02 PM
integraautox
Jul 1, 2002 11:37 PM
