crower stage 3 cams for h22
Old Nov 16, 2003 | 07:05 AM
acurafighter's Avatar
Default crower stage 3 cams for h22
anybody know if crower stage 3 cams are to large for all motor set up, are they ground for a turbo set up? would the valve train need uprating?
Old Nov 16, 2003 | 08:03 AM
HotWheelz's Avatar
Default Re: crower stage 3 cams for h22 (acurafighter)
valve train must (at least stage 1 springs) higher redline takes stage 2 springs (eibachs)
recommended you clear your rocker arms before hand.
too large ? no... ground for turbo ? no...
hella big cams... i have them.. .vtec kicks hard..
Old Nov 16, 2003 | 08:13 AM
Default Re: crower stage 3 cams for h22 (HotWheelz)
vtec kicks hard? sounds like my kinda stuff!!!!!!!!!! i`m going for a kick *** h22 but living on this rainy island called England stuff is hard to get, thanks for the info mate
Old Nov 16, 2003 | 08:59 AM
satan_srv's Avatar
i have stage 3s...I used JUN Valvetrain. It' an all motor cam that's for sure...upgrade your pistons if you can. Go type-s or something.
Stage 3 idle is loopy so you'll need to add fuel/up the idle speed to keep it from stalling.
Now I only stall on longer drives
Old Nov 16, 2003 | 09:16 AM
Default Re: crower stage 3 cams for h22 (satan_srv)
hey can you advise? i`m running a str 68mm throttle body,intake manifold,fuel rail,an aem adjustable fuel regulator, a cai and a dc cat zorst new venom injector set on the way,ive been trying to get the basics before cracking the engine open, im also using an apexi vafc, i`m guessing stage 3 cams and a valve train would help this set up, i`m a bit new to engine tuning so advice would be cool, thanks for your info it all helps!!!
Old Nov 16, 2003 | 09:24 AM
MugenPoweredLude's Avatar
youre definitely gonna need higher compression pistons to take advantage of the Stage 3's
you also have to worry about the lumpy idle and it stalling.....raising the fuel pressure/idle will help that...
and dont forget some cam gears, a good valve train and maybe a Port and Polished Head
Old Nov 16, 2003 | 09:32 AM
Wiseguy619's Avatar
Would type s pistons be a good way to go with an all-motor plan? Why would it not be a better idea to go with some pistons like JE or something? Just curious because I heard that with type s pistons, which are forged I think, there is no need to sleeve the block. Are type s pistons the way to go if you do not want to spend more cash on JE or something? Is there much of a difference in performance? Sorry about all the questions.
Old Nov 16, 2003 | 09:39 AM
Default Re: (MugenPoweredLude)
do i need to uprate pistons straight away or will the stock stuff do until more money allows? whats with the stalling issue?i`mguessing its cos of the agressive profiles?
Old Nov 16, 2003 | 10:05 AM
satan_srv's Avatar
Default Re: (acurafighter)
yes because of the aggressive non-vtec profile. I barely stall, maybe once a week after driving for an hour.
Type-S pistons do not require block sleeving, so it's cheaper. But you only have one option.
If you want driveability just get crower 2a with the stock non-vtec lobes
Old Nov 16, 2003 | 02:26 PM
CD5 Sedan's Avatar
Default Re: (satan_srv)
on crower's page regarding the h22 cams: http://www.crower.com/cat/impo...shtml what's the difference between the Stage II Cams: 63422 & 63422A. can anyone provide any information providing all that is different betweent the 2? do the Stage II cams with the stock idle lobes still provide the same (15-18hp) as advertised on the page?
Old Nov 16, 2003 | 02:37 PM
HotWheelz's Avatar
Default Re: (CD5 Sedan)
it depend what you call stalling... i have about 30 pounds removed from the rotating assembly and because of this when i ride the clutch its hard not to stall with an XTreme (ACT) so i you up the idel to 850-1000 your fine.. i had mine to 650 in town with hondata and ran smooth in 30 degree temp (celcius) but when it got colder then it would have a tendancy to stall...
so... yes the base lobes are a bit more aggresive..
Old Nov 16, 2003 | 03:32 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CD5 Sedan &raquo;</TD></TR><TR><TD CLASS="quote">on crower's page regarding the h22 cams: http://www.crower.com/cat/impo...shtml what's the difference between the Stage II Cams: 63422 & 63422A. can anyone provide any information providing all that is different betweent the 2? do the Stage II cams with the stock idle lobes still provide the same (15-18hp) as advertised on the page?</TD></TR></TABLE>
hmmm
the VTEC profile is the same, so the differnce is you don't make more power for 0-VTEC on the 2A, while with the 2 you do becuase it is more agressive.
Old Nov 16, 2003 | 03:40 PM
CD5 Sedan's Avatar
oic. thanks for the help you guys, cleared up things just right.
Old Nov 16, 2003 | 03:51 PM
NXLude's Avatar
Im pretty sure the stage 2s have the same upgraded idle lobe that the stage 3s have.....my stage 2s dont idle for beans, but I did the cams, flywheel, clutch, and crank pulley all at once so I stall more than i idle.....It will get better when tuned though....id rather have the extra low end grunt then a perfect idle
Old Nov 19, 2003 | 03:48 PM
CD5 Sedan's Avatar
Default Re: (NXLude)
so as a general consensus...are there people running or would recommend running stage III Crower n/a cams for say...a daily driven h22 accord hopefully relying on 91 oct gas. the highest comp pistons i could run and still rely on 91 is 12.2 according to rick from IB. so any help would be appreciated. of course i would buy the accompanying valvetrain to support them but junIIIs are just too expensive.
Old Nov 19, 2003 | 03:54 PM
biglew's Avatar
Has anyone confirmed if you can or cannot run JUN pistons without having to sleeve the block?
jakeiscool
Feb 9, 2005 08:13 PM
evolvedAP1
May 3, 2004 10:11 PM
Single MOBB
Jan 18, 2004 07:52 AM
Boosthead
Apr 22, 2002 08:45 AM
