People with hyper ground system.. wheres the best place to ground?
Which of you people here have the hyper ground setup thats in the import mags and ****, i know it gives you a few horse, but you have to find the best place to ground to pick it up, anybody know the best place, couldnt you just make your own hyperground system with some bigger wire of your own?
ive got a 5 wire set-up..one from the battery following the OEM ground
second wire goes from the OEM mount to the engine block
on top of the intake manifold third a wire running down to the engine block and forth wire running to the back where its attach d to the ground from inside the car
then the fifth wire runs from there to the alternator
azn_outlaw
Aug 13, 2003 11:02 PM
