High Compression D16Y8 - Need Some input
Old Nov 16, 2003 | 03:57 AM
AgentJam's Avatar
Default High Compression D16Y8 - Need Some input
My planned setup...
D16Y8
P29 pistons
Stage 2 Cam/springs/retainers
12.6:1 Compression Ratio
If i do bump my compression up this high (12.6:1) will i have to do anything more to the head than a cam/springs/retainers? Will stock valves hold that compression? Next question is...will this setup (12.6:1 compression with Stage 2 Cam) pass emissions? It will be my daily driver so i want to hear comments on similar setups.
Thanks,
VINCE
Old Nov 16, 2003 | 06:00 AM
BMac86's Avatar
Default Re: High Compression D16Y8 - Need Some input (AgentJam)
I run the Crower Stage 2, I hear that it will not pass emissions. Its worth it though! I just wanted to give you a bump because I already have the Stage2 valvetrain and am now also looking for a good deal on pistons to bump the compression. Good luck man, keep me posted!
Old Nov 16, 2003 | 06:03 AM
slammed_93_hatch's Avatar
if youre going to go that high on compression why don't you look into stage3 cams seems like a waste of compression if you don't. and on most stage2 cams if says that there is replacing of valve train parts, i would def replace the valves. as or the emissions test i dunno in CA you wouldn't but i don't know how strict PA is
Old Nov 16, 2003 | 10:34 AM
AgentJam's Avatar
Default Re: High Compression D16Y8 - Need Some input (slammed_93_hatch)
Is anyone in PA on this board running a Stage 2 cam? or anything like that? Zex Street/Strip? I mean is it the Compression that will determine emissions or the Cam that will. The reason i want a stage 2 is because it is a daily driver...i've put this question in several posts but no one can clearly answer my question. I am in PA, i wont need to pass CA smog, just emissions. Anyone with a smilar setup please elaborate!
Thanks,
VINCE
shesinmyroom
Jun 29, 2012 10:51 AM
negusjuda
Aug 24, 2010 09:37 AM
ontheline
Jan 16, 2007 07:23 PM
JDMSiGuy17
May 16, 2004 08:53 AM
red91g2
Mar 3, 2003 12:12 PM
