99 4 cyl - wouldn't start
Old Nov 16, 2003 | 12:44 AM
georgeda's Avatar
Default 99 4 cyl - wouldn't start
Drove a few blocks to store. Tried to restart 30 minutes later. I wasn't sure it was running so I turned the key off. After that it would crank but would not start. I waited 10 minutes and tried again and it started. When I got home I was able to restart it without a problem. Did I do something wrong by turning it off when I wasn't sure it was running?
Old Nov 16, 2003 | 11:25 AM
Heat's Avatar
Default Re: 99 4 cyl - wouldn't start (georgeda)
I've never had that problem (not starting) in my '99 I4, sounds like you flooded the engine.
I know the engine is quiet, get in the habit of looking at the tachometer to see if the engine is running.
Old Nov 16, 2003 | 11:46 AM
DrunkNRacer's Avatar
Default Re: 99 4 cyl - wouldn't start (Heat)
You.. you definetly flooded the engine.. those f23s in the 6th gens are undetectable in sound.. its crazy.. even if you are outside the car.. you can barely hear it. Just make sure to watch the tach when you start it.
Old Nov 16, 2003 | 11:47 AM
georgeda's Avatar
After I sent my post I remembered that I should have looked at the tach before turning the key off.
Thanks
JayTypeSH
Nov 23, 2006 01:06 PM
