Motul DOT 5.1
Old Nov 15, 2003 | 11:52 PM
spankey167's Avatar
Default Motul DOT 5.1
Has any of you guys used this? I recently bought 2 bottles and plan to bleed my old brake DOT 3/4 out and put in the Motul DOT 5.1. My question is... once i put in the Motul 5.1, is it possibly to use lower DOT 3/4 ever again? Or ever mix them? From what I've researched, it looks like i can mix DOT 3, 4 , or 5.1 together in theory because they contain Poly glycol. But I also read not to mix types or brands together either. What do you guys think? Thanx
Old Nov 16, 2003 | 07:26 PM
RotaryBzzzz's Avatar
Default Re: Motul DOT 5.1 (spankey167)
Yes you can mix. Dot 3, Dot 4, and Dot 5.1 are compatible with each other. The only thing you want to avoid mixing is silicone based stuff which is DOT 5.0 (it doesn't absorb moisture).
I like motul...good stuff!
Old Nov 16, 2003 | 08:07 PM
accordm3's Avatar
whast the difference with brake fluids... why is one better than the other
Old Nov 16, 2003 | 08:47 PM
spankey167's Avatar
Default Re: (accordm3)
DOT 5.1 has a higher dry/wet boiling point than typical DOT 3 or 4. Basically the fluid can handle hard braking without giving up braking quality. Typically used for upgraded brakes like slotted rotors or performance pads and/or steel braided brake lines.
Old Nov 17, 2003 | 01:34 AM
jjj784's Avatar
did you get ss lines? goodridge? neuspeed? =P
Old Nov 17, 2003 | 09:15 AM
iam7head's Avatar
Default Re: Motul DOT 5.1 (RotaryBzzzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotaryBzzzz &raquo;</TD></TR><TR><TD CLASS="quote">Yes you can mix. Dot 3, Dot 4, and Dot 5.1 are compatible with each other. The only thing you want to avoid mixing is silicone based stuff which is DOT 5.0 (it doesn't absorb moisture).
I like motul...good stuff!</TD></TR></TABLE>
no dude, you can step up from dot3 to dot4 but if you going from 4 to 3, you might have your brake fiuld overheated and your brake not work at all.
dot 5 is silicone based, just like you said(good knowledge) and dot 3-4 is oil based(crude oil product)
Old Nov 17, 2003 | 10:47 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordm3 &raquo;</TD></TR><TR><TD CLASS="quote">whast the difference with brake fluids... why is one better than the other</TD></TR></TABLE>
not better, i just the different grade of the fluid, one is not better than the other, it's what is design to used in your car.
dot3=most common
dot4="upgrade" version of dot3 with a higher boiling point
dot5=redesign version with silicone base instead of oil based fluid
Old Nov 17, 2003 | 11:04 AM
spankey167's Avatar
Default Re: (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
dot3=most common
dot5=redesign version with silicone base instead of oil based fluid</TD></TR></TABLE>
Don't forget about DOT 5.1 which has even a higher wet/dry boiling point than DOT 4 and 3. Which is still poly glycol based and could be used in normal vehicles.
Silicone based stuff on the other hand like DOT 5.0 is used more in military vehicles if i read correctly and doesnt absorb moisture well.
Old Nov 17, 2003 | 05:36 PM
iam7head's Avatar
Default Re: (spankey167)
5.1=too new for my ASE cert. manual
Old Nov 17, 2003 | 06:19 PM
Default Re: Motul DOT 5.1 (iam7head)
dot 5 is silicone based, just like you said(good knowledge) and dot 3-4 is oil based(crude oil product)</TD></TR></TABLE>
True. But more or less it's safe to mix 3/4/5.1. They are chemically similar.
Old Nov 17, 2003 | 06:23 PM
iam7head's Avatar
lowering boiling point of the brake fluid is not recommended in oem honda shop manual, all data systerm, mitchell on demand nor ase certified manual
just remember 3-4=okay
4-3 = let's wish you have a strong leg
Old Nov 18, 2003 | 09:36 PM
2+2=5's Avatar
oh yeah, one more note before you kill your abs box
you CANNOT use dot 5(dont know about 5.1) in abs equipped car, it will kill the abs system.
it happen when it first dot5 came out, the police department put dot 5 in their ford thinking it's safe to use dot 5 on dot 4 equipped abs car, couple months later, there's no brakes on them
Old Nov 18, 2003 | 10:47 PM
spankey167's Avatar
Default Re: Motul DOT 5.1 (2+2=5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2+2=5 &raquo;</TD></TR><TR><TD CLASS="quote">oh yeah, one more note before you kill your abs box
it happen when it first dot5 came out, the police department put dot 5 in their ford thinking it's safe to use dot 5 on dot 4 equipped abs car, couple months later, there's no brakes on them </TD></TR></TABLE>
Yea DOT 5.0 is silcone based that doesn't absorb water. While DOT 5.1 is poly glycol based like DOT 3 and 4. I have researched it all into detail
Old Nov 19, 2003 | 12:32 AM
2+2=5's Avatar
my question remains, is it safe for abs equiped car?
i know for sure 5.0 is not
dot5 is mostly used in boat trailer, doombuggie, etc
Old Nov 19, 2003 | 10:37 PM
spankey167's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2+2=5 &raquo;</TD></TR><TR><TD CLASS="quote">my question remains, is it safe for abs equiped car?
dot5 is mostly used in boat trailer, doombuggie, etc</TD></TR></TABLE>
I took a look at my Motul DOT 5.1 brake fluid. It says it works great with ABS systems.
Sidenote: I'm doing my rear disk brake conversion tomorrow with some SS lines and aem brake pads and some brembo blanks and bleeding all my old fluid out for the motul DOT 5.1. I'll keep you guys updated with some pics
Old Nov 19, 2003 | 10:53 PM
iam7head's Avatar
very very exciting news indeed, so they got around with the abs issue.
keep us updated and perhaps take some picture for the rear disk swap!
somejaykid
Suspension & Brakes
15
Apr 6, 2012 07:42 PM
Newbie808
Mar 29, 2012 08:17 AM
rjmq06
Feb 13, 2011 01:11 PM
Ghetto Civic HX
63
Oct 6, 2005 01:16 PM
MALVARO
17
Apr 15, 2004 02:33 PM
