stock/after market parts/engine parts/92-95 hatch/96-00 hatch.bay area.take a look
92-95 CIVIC
stock streering wheel (black and blue. both with air bags. blue streering wheel come with a grey air bar tho)
hadzor button (lil crack)
clock block off plate
air vent (black. the big one that gos on the passenger side dash)
front passenger speaker grill (grey)
front pasenger power window switch (grey)
front passenger door cup (grey)
audio consol housing (grey. only the housing)
center consol (blue)
center shifter consol (blue.)
front cup holders (black)
center e brake consol (blue. has lil crack)
under driver side dash panel(black. no fuse cover)
rear seat belts (black and blue. the middle one.for middle passenger)
stock wing (blue)
stock corners (2 set)
clear corners (2 set)
stock taillights (outter pieces only)
abs brake system ecu
rear lower control arms
stock front tow hooks (left and right)
stock hubcaps from 92 si(7 hub caps)
stock header from 92 si
pillar gauge pod.holds two gauges.
95 cx motor and tranny parting out(only 77k miles when i pulled it out)
aem cold air intake (red. no fliter.with bypass vavle)
96-00 CIVIC HATCH
streeing wheel with air bag (grey)
black peice that go by the cluster
gauge breezle that holds two gauges (go by the cluster)
defroster switch
power mirrior switch (grey)
sun roof switch (grey)
arm rest (grey)
oem floor matts (grey)
carpet (grey)
rear speakers grill (grey)
stock wing (black 96 cx)
stock side molding(complet 6 peice black)
stock mirriors(black)
stock tailights (96-98)
might have more interior parts.let me know what your looking for...
01 ACCORD V6 SEEDAN
stock headlight(left and right)
stock intake
96 prelude stock headlights
ENGINE PARTS
gsr cams
b series adjustable cam gear(brand unknow?)
b16 cams with cam gears(1 gen b16)
complet b20 head(vavle train need to be reasemble)
b series vtec seinold
b series water piping(from water pump)
b16 fuel rail with injecters and fpr(stock 1gen b16 head)
b series after market fuel rail(polish.brand unknow?)
d series fuel rail with fuel injecter and fpr(95 cx)
d series starter(95 cx)
d series obd1 distribator(95 cx)
d series fuel pump(95 civic cx)
d series alternator(95 cx)
5 zigen axle back muffler for 92-00 civic hatchback(will fit other cars but will have to cut and weld. dont know what model.have pics tho)
stock integra ls cluth,fly wheel,presure plate
99-00 civic si master cylinder/brake booster
TURBO PARTS
inline fuel pump(from drag 2gen turbo kit)
RIMS/SUSPENTION PARTS
94-95 integra gsr fat 5 star rims. with no tires
(8) stock honda 13 inch steel rims with 60-70 % left on tires.came off from a 95 and 96 civic cx
one rota 16inch slipsteam black with brand new falken ziex tire
integra type r center caps. all 4 in white(usdm)
92-95 civic rear lower control arm
92-95 civic stock shocks and springs(have couple of set)
integra gsr front upper control arms
integra gsr front shocks and springs
integra gsr front forks
stock wheels studs from 95 gsr brakes
can take pics if wanted.some parts i will not ship if its too big and to heavy.make offers.
from bay area..if you need vouch i can tell you some people thats can vouch for me..
thanks
stock wing (blue)
96-00 CIVIC HATCH
defroster switch
arm rest (grey)
carpet (grey)
01 ACCORD V6 SEEDAN
stock intake
ENGINE PARTS
gsr cams
TURBO PARTS
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEAM JSJ »</TD></TR><TR><TD CLASS="quote">bump.</TD></TR></TABLE>
JSJ EG6
Nov 9, 2003 11:04 PM
