injectors
well the my old motor as well as my new one are both obd 2 but i want to convert the b18c to obd1 so will my injectors still work then, cause i didnt get injectors with the bseries??
OBD1 and OBD2 injectors are both saturated types. You won't need to change them. You can use OBD2 injectors with an OBD1 ECU. You have to use the OBD2 injector plugs if you use OBD2 injectors.
