Difference between h22a4 base and h22a4 SH head question???
Old Nov 15, 2003 | 09:45 AM
cha chi's Avatar
Default Difference between h22a4 base and h22a4 SH head question???
Does anyone know if there is a difference between the h22a4 base and h22a4 Type SH head? Will the SH head work on the on the regular h22a4?
Im looking for a head right now and all i have foudn is the Type SH head.
thanks
charles
Old Nov 15, 2003 | 10:42 AM
fastludeh22's Avatar
Default Re: Difference between h22a4 base and h22a4 SH head question??? (cha chi)
there is SLIGHTLY more lift on sh cams
Old Nov 15, 2003 | 12:46 PM
cha chi's Avatar
Default Re: Difference between h22a4 base and h22a4 SH head question??? (fastludeh22)
anyone know if it will actually work? what about a jdm 92-96 fully built head, will that work without problems on the h22a4 block?
Old Nov 15, 2003 | 12:51 PM
TurboSam's Avatar
the moutning points for the intermediate shaft on the SH are different b/c of the ATTS.... well, actaully, the ATTS unit takes place of the intermediate shaft, but anyways..... so if you are using an SH block but not planning to use ATTS, you will need to fabricate some sort of bracket to accomidate the intermediate shaft. oh, and the oil filter is also located in a different spot too
Old Nov 15, 2003 | 01:21 PM
cha chi's Avatar
Default Re: Difference between h22a4 base and h22a4 SH head question??? (Turbo Sam)
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Sam &raquo;</TD></TR><TR><TD CLASS="quote">the moutning points for the intermediate shaft on the SH are different b/c of the ATTS.... well, actaully, the ATTS unit takes place of the intermediate shaft, but anyways..... so if you are using an SH block but not planning to use ATTS, you will need to fabricate some sort of bracket to accomidate the intermediate shaft. oh, and the oil filter is also located in a different spot too</TD></TR></TABLE>
oh sorry, im using the base model h22a4 block. im looking to see if i can use an A4 type sh head on that that, or if i can use the older 92-96 head
dixie Normas7
Sep 27, 2006 01:32 PM
k20tegtuner
Jul 24, 2006 12:48 AM
hybridpatient95
May 9, 2006 10:43 AM
98TypeSH
Jul 26, 2004 06:35 PM
AndyD
Jan 5, 2003 01:40 PM
