Stock B16 running VERY rich
Old Nov 15, 2003 | 08:36 AM
slamdunkcivic's Avatar
Default Stock B16 running VERY rich
Just had my B16A2 powered civic on the dyno today and the AFR is way off, its 12 to 1 all the other B16's were something like 13/14 to 1.
It has Intake, and no cat, but thats all, the fuelling is effecting the power big time any ideas? Car and engine are 92-95, it has the obd1 ecu. When I took the plugs out last night they were black with a hint of grey on the tip. 2 Months ago the plugs were burning perfect. I thought something was up but not as bad as it is!
PLEASE can someone advise what to do, I was told it could be a sensor or something, although no codes are showing.
Thanks
Old Nov 15, 2003 | 12:31 PM
stock ecu, 02 sensor in and connected, no check engine lights are showing.
Old Nov 15, 2003 | 01:32 PM
Plugs were fitted same day, correctly gapped, cap and rota are a year and 8000 mile old, god only knows how old the 02 sensor is, Ive had it 3 years and never changed it, all fuel system is stock, injectors, pump, regulator etc.
Injectors have been recently cleaned.
Timing is set at stock.
Old Nov 16, 2003 | 09:15 AM
tttttop!
scottso990
Apr 15, 2008 04:14 AM
JDM_EK4_Coupe
Apr 24, 2007 07:08 PM
0260MOTORSPORTS
Dec 23, 2006 02:59 PM
Brian77769
10
Feb 9, 2006 03:33 AM
Colin
Jan 9, 2003 12:32 AM
